[mpich-discuss] help
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Oct 14 12:33:17 CDT 2011
 You are getting this error message because you registered an incorrect username+password with mpiexec.
 Use the "-remove" option of mpiexec to remove the registered username/password and register the correct username/password using the "-register" option of mpiexec. (mpiexec -remove; mpiexec -register)
Jayesh
----- Original Message -----
Sent: Friday, October 14, 2011 10:30:57 AM
Subject: [mpich-discuss] help
the installation processing is all right,but when I run the mpi-program(eg. the given one cpi.exe in the examples folder) the error occurs. as follows :
C:\Program Files\MPICH2\bin>mpiexec -n 4 cpi
Credentials for reed rejected connecting to reed-PC
Aborting: Unable to connect to reed-PC
and I have stop the firewall.the smpd has been configed right.
wanna the solution.
reed
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
