[mpich-discuss] MPICH2 on Windows 7
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Oct 12 14:42:04 CDT 2011
The debug option only logs events from the process manager (Not the MPI processes). If you need to debug MPICH2 you will need to build debug versions of the MPI libraries.
(PS: You can look at the SMPD source code if you need more info - https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/src/pm/smpd/)
Jayesh
----- Original Message -----
Sent: Tuesday, October 11, 2011 2:06:43 PM
Subject: [mpich-discuss] MPICH2 on Windows 7
I seem to having a problem getting complete log information from SMPD –d. The test program runs fine. I can see the right number of cpi.exe processes. SMPD was started as admin after doing a smpd –stop. But the log debug output does not look like it is giving all the information or gives up very early.
Mpiexec –n 2 cpi.exe
Output from smpd –d:
[-1:41864]...\smpd_get_opt_int
[-1:41864].../smpd_get_opt_int
[-1:41864]...\smpd_get_opt_string
[-1:41864].../smpd_get_opt_string
[-1:41864]../smpd_parse_command_args
[-1:41864]..\smpd_get_smpd_data
[-1:41864]...\smpd_get_smpd_data_from_environment
[-1:41864].../smpd_get_smpd_data_from_environment
[-1:41864]...\smpd_get_smpd_data_default
[-1:41864].../smpd_get_smpd_data_default
[-1:41864]../smpd_get_smpd_data
[-1:41864]..\smpd_entry_point
[00:41864]...\smpd_set_smpd_data
[00:41864].../smpd_set_smpd_data
[00:41864]...\SMPDU_Sock_create_set
[00:41864]....\SMPDU_Sock_get_sock_set_id
[00:41864]..../SMPDU_Sock_get_sock_set_id
[00:41864]....created a set for the listener: 604
[00:41864]....\SMPDU_Sock_listen
[00:41864]..../SMPDU_Sock_listen
[00:41864]....smpd listening on port 8678
[00:41864]....\smpd_create_context
[00:41864].....\smpd_init_context
[00:41864]......\smpd_init_command
[00:41864]....../smpd_init_command
[00:41864]......\SMPDU_Sock_set_user_ptr
[00:41864]....../SMPDU_Sock_set_user_ptr
[00:41864]...../smpd_init_context
[00:41864]..../smpd_create_context
[00:41864]....\SMPDU_Sock_set_user_ptr
[00:41864]..../SMPDU_Sock_set_user_ptr
[00:41864]....\smpd_option_on
[00:41864].....\smpd_get_smpd_data
[00:41864]......\smpd_get_smpd_data_from_environment
[00:41864]....../smpd_get_smpd_data_from_environment
[00:41864]......\smpd_get_smpd_data_default
[00:41864]....../smpd_get_smpd_data_default
[00:41864]......Unable to get the data for the key 'no_dynamic_hosts'
[00:41864]...../smpd_get_smpd_data
[00:41864]..../smpd_option_on
[00:41864]....\smpd_insert_into_dynamic_hosts
[00:41864]..../smpd_insert_into_dynamic_hosts
[00:41864]....\smpd_enter_at_state
[00:41864].....sock_waiting for the next event.
[00:41864].....\SMPDU_Sock_wait
[00:41864]...../SMPDU_Sock_wait
[00:41864].....SOCK_OP_ACCEPT
[00:41864].....\smpd_handle_op_accept
[00:41864]......\smpd_state_smpd_listening
[00:41864].......\SMPDU_Sock_accept
[00:41864]......./SMPDU_Sock_accept
[00:41864].......authenticating new connection
[00:41864].......\smpd_create_context
[00:41864]........\smpd_init_context
[00:41864].........\smpd_init_command
[00:41864]........./smpd_init_command
[00:41864].........\SMPDU_Sock_set_user_ptr
[00:41864]........./SMPDU_Sock_set_user_ptr
[00:41864]......../smpd_init_context
[00:41864]......./smpd_create_context
[00:41864].......\SMPDU_Sock_set_user_ptr
[00:41864]......./SMPDU_Sock_set_user_ptr
[00:41864].......\smpd_gen_authentication_strings
[00:41864]........\smpd_hash
[00:41864]......../smpd_hash
[00:41864]......./smpd_gen_authentication_strings
[00:41864].......posting a write of the challenge string: 3.1 5676
[00:41864].......\SMPDU_Sock_post_write
[00:41864]........\SMPDU_Sock_post_writev
[00:41864]......../SMPDU_Sock_post_writev
[00:41864]......./SMPDU_Sock_post_write
[00:41864]....../smpd_state_smpd_listening
[00:41864]...../smpd_handle_op_accept
[00:41864].....SOCK_OP_WRITE
[00:41864].....\smpd_handle_op_write
[00:41864]......\smpd_state_writing_challenge_string
[00:41864].......wrote challenge string: '3.1 5676'
[00:41864].......\SMPDU_Sock_post_read
[00:41864]........\SMPDU_Sock_post_readv
[00:41864]......../SMPDU_Sock_post_readv
[00:41864]......./SMPDU_Sock_post_read
[00:41864]....../smpd_state_writing_challenge_string
[00:41864]...../smpd_handle_op_write
[00:41864].....SOCK_OP_READ event.error = 0, result = 0, context->type=20
[00:41864].....\smpd_handle_op_read
[00:41864]......\smpd_state_reading_challenge_response
[00:41864].......read challenge response: 'fbc7aa3f86387511622eac4177c4d071'
[00:41864]....../smpd_state_reading_challenge_response
[00:41864]...../smpd_handle_op_read
[00:41864]......\smpd_state_writing_connect_result
[00:41864].......wrote connect result: 'SUCCESS'
[00:41864]....../smpd_state_writing_connect_result
[00:41864]......\smpd_state_reading_session_request
[00:41864].......read session request: 'process'
[00:41864]....../smpd_state_reading_session_request
[00:41864]......\smpd_state_writing_no_cred_request
[00:41864].......wrote no cred request: 'nocredentials'
[00:41864].......\smpd_start_win_mgr
[00:41864]........starting command: "C:\Program Files (x86)\Common Files\Intel\S
hared Libraries\redist\intel64\mpirt\smpd.exe" -d 27 -mgr -pipe smpd_temporary_p
ipe
[00:41864]........CreateProcess
[00:41864]........smpd reading the port string from the manager
[00:41864]........smpd sending the account to the manager
[00:41864]........\smpd_hide_string_arg
[00:41864].........\first_token
[00:41864]........./first_token
[00:41864].........\compare_token
[00:41864]........./compare_token
[00:41864].........\next_token
[00:41864]..........\first_token
[00:41864]........../first_token
[00:41864]........./next_token
[00:41864]......../smpd_hide_string_arg
[00:41864]........closing the pipe to the manager
[00:41864]........smpd writing reconnect request: port 60913
[00:41864].........\SMPDU_Sock_post_writev
[00:41864]........./SMPDU_Sock_post_writev
[00:41864]......./smpd_state_writing_no_cred_request
[00:41864]....../smpd_handle_op_write
[00:41864]......sock_waiting for the next event.
[00:41864]......\SMPDU_Sock_wait
[00:41864]....../SMPDU_Sock_wait
[00:41864]......SOCK_OP_WRITE
[00:41864]......\smpd_handle_op_write
[00:41864].......\smpd_state_writing_reconnect_request
[00:41864]........wrote reconnect request: '60913'
[00:41864]........\SMPDU_Sock_post_close
[00:41864].........\SMPDU_Sock_post_read
[00:41864]..........\SMPDU_Sock_post_readv
[00:41864]........../SMPDU_Sock_post_readv
[00:41864]........./SMPDU_Sock_post_read
[00:41864]......../SMPDU_Sock_post_close
[00:41864]......./smpd_state_writing_reconnect_request
[00:41864]......SOCK_OP_CLOSE
[00:41864]......\smpd_handle_op_close
[00:41864].......\smpd_get_state_string
[00:41864]......./smpd_get_state_string
[00:41864].......op_close received - SMPD_CLOSING state.
[00:41864].......Unaffiliated undetermined context closing.
[00:41864].......\smpd_free_context
[00:41864]........freeing undetermined context.
[00:41864]......./smpd_free_context
[00:41864]....../smpd_handle_op_close
Even though cpi.exe is still running and I enter many interval numbers – I never see any additional log entries.
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
