[mpich-discuss] MPI_Alltoall problem
    Jie Chen
    jiechen at mcs.anl.gov
    Sat Oct  8 11:49:45 CDT 2011
Jeff, you are right, in my case fft is used to perform matrix vector multiplications. I expect using fast multipole would alleviate the problem since it does not need all-to-all of the whole data.
Jie
On Oct 8, 2011, at 10:30 AM, Jeff Hammond <jhammond at alcf.anl.gov> wrote:
> It is unlikely that you will find anything significantly better at FFT
> than FFTW.
> The best solution to your problem is to not call FFT millions or
> billions of times.  My guess is your algorithm does not actually
> require FFT but rather chose it as one of many possibilities based
> upon the availability of good libraries like FFTW or the assumption of
> performance of hardware from many years ago.
> If you're doing molecular dynamics (quantum or classical), then the
> problem is that you're using the wrong algorithm for Coulomb solves.
> I can point you to codes that do not require an FFT every iteration
> and therefore are more scalable.
> Another way to solve this is to run on hardware that does MPI_Alltoall
> really fast, e.g. Blue Gene/P.  Since you're at Argonne, this is
> clearly feasible, although it is unlikely to impress any
> mathematicians :-)
> I am O(1) doors down the hall from you on the first floor of TCS if
> you want to stop by to talk about this problem in more detail some
> time.
> Jeff
> On Sat, Oct 8, 2011 at 5:40 AM, Jie Chen <jiechen at mcs.anl.gov> wrote:
>> Rhys: thank you for the heads up. Actually my question stems from using fftw. I do not feel fftw fast enough, considering that I need to do the transforms millions, even billions times.  I timed its routine and found that it was actually the transpose of the data that killed me. I know that when creating the plan, fftw would test different options, including the mpi_alltoall way, and choose the fastest option to do transpose. I just hope that someone here might have a smarter solution that what fftw provides...
>> Jie
>> On Oct 8, 2011, at 4:52 AM, Rhys Ulerich <rhys.ulerich at gmail.com> wrote:
>>>> Hi, I am working on some application that heavily uses MPI_Alltoall---matrix transpose.
>>>> ... So the performance of MPI_Alltoall becomes very critical. Does anyone know an
>>>> alternative to directly calling the MPI_Alltoall routine and reduce the run time?
>>> One possibility would be trying FFTW 3.3's MPI transpose capabilities
>>> [1].  You pay a
>>> one-time planning cost while FFTW figures out what the fastest way is
>>> to perform your
>>> transpose (Alltoall, pairwise sendrecv, etc) and then you can
>>> repeatedly execute the
>>> optimum choice.
>>> If this looks like a good option, be sure to read the entire FFTW MPI chapter as
>>> many of the useful tidbits are buried within it (e.g. [2]).  Lastly,
>>> if you structure your
>>> computation so that you perform an MPI transpose of your matrix A and in the
>>> "transposed" logic you compute with data strided like A^T, you may find that
>>> FFTW_MPI_TRANSPOSED_OUT [3] will improve your runtime.
>>> Hope that helps,
>>> Rhys
>>> [1] http://www.fftw.org/fftw3_doc/FFTW-MPI-Transposes.html#FFTW-MPI-Transposes
>>> [2] http://www.fftw.org/fftw3_doc/FFTW-MPI-Performance-Tips.html#FFTW-MPI-Performance-Tips
>>> [3] http://www.fftw.org/fftw3_doc/Transposed-distributions.html#Transposed-distributions
>>> _______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki.alcf.anl.gov/index.php/User:Jhammond
