[mpich-discuss] MPICH2
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Oct  7 11:08:31 CDT 2011
 Youri is right. And if you have been running your code with SHM channel (mpiexec -channel shm ...) you should be able to use NEMESIS channel instead (mpiexec -channel nemesis ...).
Jayesh
----- Original Message -----
From: "Youri LACAN-BARTLEY" <youri.lacan-bartley at transvalor.com>
Sent: Friday, October 7, 2011 5:27:21 AM
Subject: Re: [mpich-discuss] MPICH2
I believe this is due to the fact that the SHM channel is deprecated.
The Windows build for MPICH2 1.4.1.p1 doesn't provide mpich2shm.dll so your best option is probably to get opentemac to run using the nemesis channel.
Y.
-----Message d'origine-----
De : mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] De la part de Tuong
Envoyé : vendredi 7 octobre 2011 07:37
À : mpich-discuss at mcs.anl.gov
Objet : [mpich-discuss] MPICH2
Dear sir\ Madam!
I am trying to use MPICH2 to calculate hydraulic modelling.
I installed MPICH2 version 1.4.1.p1 in window 7 64bit
I tested wmpiconfig and it is ok ( green my host)
But when I run opentemac program require MPI and error that " unable
load mpich2shm.dll" . Could you help me fix problem?
Thank you
Mr.  Vo Quang Tuong
technical staff of pmu 1547
Steering Center of the Urban Flood Control Program
10 Tran Nhat Duat St. Tan Dinh Ward. Dist. 1, HCMC
Tel. 0937007545;
Email: tuong_odise at yahoo.com
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
