[mpich-discuss] Ask questions with MPI's installation
Nicolas Rosner
nrosner at gmail.com
Tue Nov 29 08:36:03 CST 2011
Sounds like your shell is confused about what exactly you want to
redirect where. This can happen if, for instance, you try to use bash
redirection syntax while running csh/tcsh, or viceversa, or when there
are too many or too few elements on the command line. Here's an
example that triggers a similar message on my system:
$ myfile="one two"
$ echo Hello >$myfile
-bash: $myfile: ambiguous redirect
If this information doesn't help, please copy-paste the full error
message text and include some further details about your system
(platform, OS, shell type if applicable, etc).
Good luck
N.
On Tue, Nov 29, 2011 at 5:37 AM, chen <syuuchi at esst.kyushu-u.ac.jp> wrote:
> Hello
> Excuse me, I used the MPICH2 Installer's Guide to install the MPI, but I
> cannot install it successfully. In the process of the installation, I
> meet the information which told me the installation was wrong. the
> content of the information is "Ambiguous output redirect".
> Could you tell me how I should do ?
> Thank you.
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
