[mpich-discuss] no process manager installed?
    Darius Buntinas
    buntinas at mcs.anl.gov
    Sun Nov 20 11:15:48 CST 2011
I'm glad to hear it!
-d
Sent from my iPhone
On Nov 19, 2011, at 12:28 AM, Rolf Kuiper <kuiper at mpia.de> wrote:
> That's it; the issue is resolved.
> When using the mpicc and mpiexec with hydra from /usr/local/ everything works fine.
> Thanks a lot for your help,
> Rolf
> Am 18.11.2011 um 18:24 schrieb Darius Buntinas:
>> Mpd is not installed or supported anymore.
>> The Mac comes with another MPI installed so when you call mpexec, it's probably choosing the mpiexec from other implementation.  Try using the full path for both mpicc and mpiexec.
>> -d
>> Sent from my iPhone
>> On Nov 18, 2011, at 6:32 PM, Rolf Kuiper <kuiper.rolf at googlemail.com> wrote:
>>> I did. But also the /usr/bin/ contains no mpd to start, ...
>>> Also "which mpd" gives me no result.
>>> Rolf
>>> Am 18.11.2011 um 17:22 schrieb Darius Buntinas:
>>>> Make sure you do a "make install". The bin directory in the build tree won't have all of the binaries.
>>>> -d
>>>> Sent from my iPhone
>>>> On Nov 18, 2011, at 4:56 PM, Rolf Kuiper <kuiper.rolf at googlemail.com> wrote:
>>>>> Hi Rajeev,
>>>>> thanks for your prompt reply!
>>>>> Sounds promising, but when I ask for the local rank number via
>>>>> 	MPI_Comm_rank(MPI_COMM_WORLD, &myrank);
>>>>> all ranks state to be myrank = 0. So I cannot e.g. use
>>>>> 	if(myrank == 0) ...
>>>>> Is there a new/updated routine of  MPI_Comm_rank() available or ...?
>>>>> Thanks for your help,
>>>>> Rolf
>>>>> Am 18.11.2011 um 14:38 schrieb Rajeev Thakur:
>>>>>> You no longer need to separately run a process manager. Just run the program with mpiexec.
>>>>>> Rajeev
>>>>>> On Nov 18, 2011, at 3:40 PM, Rolf Kuiper wrote:
>>>>>>> Dear MPI users,
>>>>>>> when installing MPICH2 (mpich2-1.4.1p1) from source, I am missing the process manager (mpd or hydra); the resulting bin directory only contains mpicc, mpicxx, mpif77, and mpif90.
>>>>>>> I have tried this on Intel Macs with MacOSX 10.7 (Lion) and MacOSX 10.6 (Snow Leopoard). My older installations on different Linux machines/cluster and an old PowerPC Mac never showed such behavior.
>>>>>>> I cannot run programs in parallel without a process manager, right?
>>>>>>> Do you any help or recommendation for me?
>>>>>>> Thanks,
>>>>>>> Rolf
>>>>>>> _______________________________________________
>>>>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>>>>> To manage subscription options or unsubscribe:
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111120/3517254a/attachment.htm>
