[mpich-discuss] no process manager installed?
    Rolf Kuiper
    kuiper.rolf at googlemail.com
    Fri Nov 18 19:31:57 CST 2011
I did. But also the /usr/bin/ contains no mpd to start, ...
Also "which mpd" gives me no result.
Rolf
Am 18.11.2011 um 17:22 schrieb Darius Buntinas:
> Make sure you do a "make install". The bin directory in the build tree won't have all of the binaries.
> -d
> Sent from my iPhone
> On Nov 18, 2011, at 4:56 PM, Rolf Kuiper <kuiper.rolf at googlemail.com> wrote:
>> Hi Rajeev,
>> thanks for your prompt reply!
>> Sounds promising, but when I ask for the local rank number via
>> 	MPI_Comm_rank(MPI_COMM_WORLD, &myrank);
>> all ranks state to be myrank = 0. So I cannot e.g. use
>> 	if(myrank == 0) ...
>> Is there a new/updated routine of  MPI_Comm_rank() available or ...?
>> Thanks for your help,
>> Rolf
>> Am 18.11.2011 um 14:38 schrieb Rajeev Thakur:
>>> You no longer need to separately run a process manager. Just run the program with mpiexec.
>>> Rajeev
>>> On Nov 18, 2011, at 3:40 PM, Rolf Kuiper wrote:
>>>> Dear MPI users,
>>>> when installing MPICH2 (mpich2-1.4.1p1) from source, I am missing the process manager (mpd or hydra); the resulting bin directory only contains mpicc, mpicxx, mpif77, and mpif90.
>>>> I have tried this on Intel Macs with MacOSX 10.7 (Lion) and MacOSX 10.6 (Snow Leopoard). My older installations on different Linux machines/cluster and an old PowerPC Mac never showed such behavior.
>>>> I cannot run programs in parallel without a process manager, right?
>>>> Do you any help or recommendation for me?
>>>> Thanks,
>>>> Rolf
>>>> _______________________________________________
>>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>>> To manage subscription options or unsubscribe:
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111118/65f59ba7/attachment.htm>
