[mpich-discuss] Segmentation Fault when running any application.
Michael Warthon michael.warthon at upr.edu
Thu Nov 17 14:54:37 CST 2011
Ok well I did a bit of searching on past discussions and it looks like the
error will come up but won't affect how the program will run. However, it
seems that I keep getting out of one problem and running into another. When
I tried to compile the hello.c file again I got this error:
/usr/lib/gcc/i686-pc-cygwin/4.5.3/../../../../i686-pc-cygwin/bin/ld: cannot
find
 -lmpi
collect2: ld returned 1 exit status
I want to make sure that other executable will work for mpiexec so I would
like to be able to compile hello.c and then test to see if it will run or
not.
On Thu, Nov 17, 2011 at 12:38 PM, Michael Warthon
<michael.warthon at upr.edu>wrote:
> Thank you. Unfortunately I still get the same error regarding the closing
> of the left context socket.
> On Thu, Nov 17, 2011 at 2:28 PM, Jose Marques <jmarques at itn.pt> wrote:
>> Michael,
>> There's a good set of instructions in
>> http://www.petri.co.il/disable-uac-in-windows-7.htm
>> Rds,
>>   Jose
>> On 17-11-2011 6:12, Michael Warthon wrote:
>> How do I go about turning that off?
>> On Nov 17, 2011, at 2:05 PM, Jose Marques <jmarques at itn.pt> wrote:
>>  Michael,
>> Did you switch off User Account Control in Windows 7 ? I think I had the
>> same probs and solved them taking care of UAC.
>> Jose
>> On 17-11-2011 5:35, Michael Warthon wrote:
>> I am still getting the same error even after reinstalling SMPD. The
>> MPICH2 that I have installed is the 64-bit version. My computer has windows
>> 7, is a 64-bit operating system, and has an intel core i5 CPU processor.
>> The installer I used mpich2-1.4.1p1-win-x86-64.msi is the correct one right?
>> On Thu, Nov 17, 2011 at 12:22 PM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>>> Hi,
>>>  The error message does not appear with the "-verbose" option (The
>>> launch mechanism with a "-verbose" option is different though).
>>>  I think that the issue is still that MPICH2 was not installed correctly
>>> in your system (I verified that 1.4.1p1 works correctly - without error
>>> msgs - on our Srv2008). Please follow the steps below and let us know if it
>>> works for you,
>>> # Right-click on the command prompt icon and select "Run as
>>> administrator" to open an admin command prompt
>>> # From the admin command prompt, uninstall SMPD using the "-uninstall"
>>> option (Type "smpd -uninstall")
>>> # From the admin command prompt, install SMPD using the "-install"
>>> option (Type "smpd -install")
>>> # Try running mpiexec from the admin command prompt (Type "mpiexec -n 2
>>> hostname")
>>> # Try running mpiexec from a normal command prompt (Type "mpiexec -n 2
>>> hostname")
>>>  Let us know the results.
>>> Regards,
>>> Jayesh
>>> ----- Original Message -----
>>> From: "Michael Warthon" <michael.warthon at upr.edu>
>>> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>>> Cc: mpich-discuss at mcs.anl.gov
>>>  Sent: Thursday, November 17, 2011 10:10:28 AM
>>> Subject: Re: [mpich-discuss] Segmentation Fault when running any
>>> application.
>>> Alright. Attached is the text file with the complete message from the
>>> command: "c:\Program Files\MPICH2\bin\mpiexec" -verbose -n 2 hostname
>>> I tried the other command and for some reason I am actually able to run
>>> the program even when the errors occur. This is the response I got when
>>> running the command:
>>> C:\Users\Mike>"c:\Program Files\MPICH2\bin\mpiexec" -n 2 "C:\Program
>>> Files\MPICH
>>> 2\examples\cpi.exe"
>>> error closing the left context socket: Error = -1
>>> Enter the number of intervals: (0 quits) 100
>>> pi is approximately 3.1416009869231241, Error is 0.0000083333333309
>>> wall clock time = 0.000541
>>> pi is approximately 3.1424259850010983, Error is 0.0008333314113051
>>> wall clock time = 0.000047
>>> Enter the number of intervals: (0 quits) 0
>>> op_read error on left context: Error = -1
>>> unable to read the cmd header on the left context, Error = -1
>>> Error posting readv, An existing connection was forcibly closed by the
>>> remote ho
>>> st.(10054)
>>> On Thu, Nov 17, 2011 at 9:56 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> Yes, please give us the output of the command with "-verbose" turned on.
>>> And for these tests, run mpiexec with the complete path ("c:\Program
>>> Files\MPICH2\bin\mpiexec" -verbose -n 2 hostname). Do you get the same
>>> error message when executing cpi ("c:\Program Files\MPICH2\bin\mpiexec" -n
>>> 2 "C:\Program Files\MPICH2\examples\cpi.exe")?
>>> Regards,
>>> Jayesh
>>> From: "Michael Warthon" < michael.warthon at upr.edu >
>>> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
>>> Sent: Thursday, November 17, 2011 9:42:42 AM
>>> application.
>>> For each command, this is the entire response that I get:
>>> C:\Users\Mike>mpiexec -validate
>>> SUCCESS
>>> C:\Users\Mike>mpiexec -n 2 hostname
>>> Mike-PC
>>> Mike-PC
>>> C:\Users\Mike>
>>> Did you want me to use the verbose option?
>>> On Thu, Nov 17, 2011 at 9:21 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> Please copy-paste the command and the response (the complete message) in
>>> your email.
>>> Are you able to validate the registered username/password (Type "mpiexec
>>> -validate" and it should return "SUCCESS")?
>>> Regards,
>>> Jayesh
>>> Sent: Thursday, November 17, 2011 7:50:25 AM
>>> application.
>>> Ok. I have checked and yes smpd is running and I have given a sufficient
>>> username and password so that mpiexec will run. Now I am getting a new
>>> error when executing mpiexec -n 2 hostname where it is giving me this
>>> response:
>>> On Wed, Nov 16, 2011 at 2:21 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> 1. Make sure that the process manager, smpd, is running in your system
>>> (Look in the task manager/Process Explorer to see if there is a service
>>> named smpd running. Alternately you can run "smpd -status" to check if smpd
>>> is running)
>>> 2. Run a simple non-MPI program like hostname from the command prompt
>>> using mpiexec (Type "mpiexec -n 2 hostname" ). When prompted for
>>> username/password give a valid Windows username/password.
>>> If mpiexec gives you an error, type "mpiexec -remove" to remove the
>>> existing registered username/password and then type "mpiexec -register" to
>>> register a new/valid Windows username/password. Re-run mpiexec.
>>> 3. Run the sample MPI program, cpi.exe, provided with MPICH2 (mpiexec -n
>>> 2 C:\Progra~1\MPICH2\examples\cpi.exe)
>>> >> I am getting an error when I look at the MPICH2 configurable settings
>>> This is a known bug. Due to limited developer bandwidth we haven't been
>>> able to address this issue yet.
>>> Regards,
>>> Jayesh
>>> Sent: Wednesday, November 16, 2011 12:27:01 PM
>>> application.
>>> Alright. I have reinstalled MPICH2 using the method in section 9.4.
>>> However, I am not able to connect to the host it seems. I keep receiving
>>> this message when trying to execute a program:
>>> Credentials for Mike rejected connecting to Mike-PC
>>> Aborting: Unable to connect to Mike-PC
>>> Also, I am getting an error when I look at the MPICH2 configurable
>>> settings that says that MPICH2 is not installed or that it cannot query the
>>> host.
>>> On Wed, Nov 16, 2011 at 9:35 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> Looks like MPICH2 was not installed correctly in your system.
>>> Uninstall your existing version of MPICH2. Please follow the steps in
>>> Section 9.4 (Not 9.1 -
>>> http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf) of the installer's guide to install MPICH2.
>>> (PS: I am assuming that you have Win7/Srv2008/...)
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, November 15, 2011 9:04:57 PM
>>> application.
>>> Yeah it must have been that I got the installation mixed up. I
>>> downloaded the windows installer and it finally compiled. So progess has
>>> been made as now I am getting this error when trying to run hello.exe:
>>> Error while connecting to host, No connection could be made because the
>>> target m
>>> achine actively refused it. (10061)
>>> Connect on sock (host=localhost, port=8676) failed, exhaused all end
>>> points
>>> Unable to connect to 'localhost:8676',
>>> sock error: Error = -1
>>> On Tue, Nov 15, 2011 at 5:12 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> There are two ways you can use MPICH2 on Windows+cygwin,
>>> # Download MPICH2 source compile/install it on Cygwin. Use mpicc to
>>> compile and use mpiexec (from this installation - NOT the one available
>>> with Windows installer) to run your program.
>>> # Download MPICH2 Windows installer, install MPICH2 (using installer
>>> gui). Use the cygwin/gcc libs provided with the Windows installation to
>>> compile your code. Use mpiexec from the Windows installation to run your
>>> job.
>>> Looks like you are mixing the approaches.
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, November 15, 2011 1:03:02 PM
>>> application.
>>> I was using mpicc in order to compile it. Unfortunately I am still not
>>> able to compile the code even with the command you gave me. I used:
>>> gcc -l/mpich_install/include -L/mpich_install/lib hello.c -lmpi
>>> I still received the same error. Did I install it incorrectly maybe?
>>> On Tue, Nov 15, 2011 at 12:42 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> How were you compiling your code before ?
>>> A command similar to,
>>> "gcc -I/cygdrive/c/Progra~1/MPICH2/include
>>> -L/cygdrive/c/Progra~1/MPICH2/lib hello.c -o hello.exe -lmpi"
>>> should work.
>>> Regards,
>>> jayesh
>>> Sent: Tuesday, November 15, 2011 12:18:43 PM
>>> application.
>>> Alright. Well I tried it and for some reason it is not able to see the
>>> library.
>>> I used the command:
>>> gcc -g hello.c -L\mpich_install\lib -lmpi
>>> It ended up giving me an error saying:
>>> fatal error: mpi.h: No such file or directory
>>> On Tue, Nov 15, 2011 at 10:32 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> Try using gcc (usual gcc stuff: specify include dirs using "-I", lib
>>> dirs using "-L") to compile your code and link it with "-lmpi" .
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, November 15, 2011 10:16:00 AM
>>> application.
>>> What would be the correct command to use in cygwin in order to compile
>>> the code? Just want to make sure that I actually compiled it correctly.
>>> On Tue, Nov 15, 2011 at 10:10 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Hi,
>>> I just tried compiling your code with cygwin gcc (3.4.4) + MPICH2
>>> 1.4.1p1 gcc libs and it worked for me (No seg fault, gives the expected
>>> output).
>>> Make sure that you are using the correct header files and libraries
>>> (MPICH2 libs and headers) when you compile your code.
>>> Regards,
>>> Jayesh
>>> Sent: Tuesday, November 15, 2011 9:53:32 AM
>>> application.
>>> Ah sorry. I forgot to include the p1 at the end of it. I am using mpich2
>>> 1.4.1p1
>>> On Tue, Nov 15, 2011 at 9:44 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>>> wrote:
>>> Did you try the latest stable release (1.4.1p1)?
>>> -Jayesh
>>> To: mpich-discuss at mcs.anl.gov
>>> Sent: Monday, November 14, 2011 7:54:43 PM
>>> Subject: [mpich-discuss] Segmentation Fault when running any application.
>>> Hello,
>>> I am new to MPI and I went and installed mpich2 1.4.1 onto a windows
>>> system that is being used through cygwin. I have compiled the code that
>>> simply prints the process and rank as shown below.
>>> #include <stdio.h>
>>> #include <mpi.h>
>>> int main( int argc, char *argv[]) {
>>> int numprocs, rank, namelen;
>>> char processor_name[MPI_MAX_PROCESSOR_NAME];
>>> MPI_Init(&argc, &argv);
>>> MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
>>> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>>> MPI_Get_processor_name(processor_name, &namelen);
>>> printf( "Process %d on %s out of %d\n" , rank, processor_name, numprocs);
>>> MPI_Finalize();
>>> Nothing too complicated. However, I still receive an error from the
>>> command line in cygwin that simply reads segmentation fault: (core dumped).
>>> The command I used was:
>>> mpiexec -n 1 a.exe
>>> No matter what executable I try to run, I still receive the same error.
>>> Any help regarding this would be greatly appreciated!
>>> _______________________________________________
>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> To manage subscription options or unsubscribe:https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Dr. Jose G. Marques
>> Reactor Manager
>> Instituto Tecnologico e Nuclear     phone:  (+351) 219 946 115
>> Estrada Nacional 10                 fax:    (+351) 219 941 039
>> P-2686-953 Sacavem, Portugal
>> Dr. Jose G. Marques
>> Reactor Manager
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111117/6d4477b4/attachment-0001.htm>
