[mpich-discuss] Segmentation Fault when running any application.
    Jose Marques
    jmarques at itn.pt
    Thu Nov 17 12:28:28 CST 2011
Michael,
There's a good set of instructions in
http://www.petri.co.il/disable-uac-in-windows-7.htm
Rds,
   Jose
On 17-11-2011 6:12, Michael Warthon wrote:
> How do I go about turning that off?
> On Nov 17, 2011, at 2:05 PM, Jose Marques <jmarques at itn.pt
> <mailto:jmarques at itn.pt>> wrote:
>> Michael,
>> Did you switch off User Account Control in Windows 7 ? I think I had
>> the same probs and solved them taking care of UAC.
>> Jose
>> On 17-11-2011 5:35, Michael Warthon wrote:
>>> I am still getting the same error even after reinstalling SMPD. The
>>> MPICH2 that I have installed is the 64-bit version. My computer has
>>> windows 7, is a 64-bit operating system, and has an intel core i5
>>> CPU processor. The installer I used mpich2-1.4.1p1-win-x86-64.msi is
>>> the correct one right?
>>> On Thu, Nov 17, 2011 at 12:22 PM, Jayesh Krishna <jayesh at mcs.anl.gov
>>> <mailto:jayesh at mcs.anl.gov>> wrote:
>>>     Hi,
>>>      The error message does not appear with the "-verbose" option
>>>     (The launch mechanism with a "-verbose" option is different though).
>>>      I think that the issue is still that MPICH2 was not installed
>>>     correctly in your system (I verified that 1.4.1p1 works
>>>     correctly - without error msgs - on our Srv2008). Please follow
>>>     the steps below and let us know if it works for you,
>>>     # Right-click on the command prompt icon and select "Run as
>>>     administrator" to open an admin command prompt
>>>     # From the admin command prompt, uninstall SMPD using the
>>>     "-uninstall" option (Type "smpd -uninstall")
>>>     # From the admin command prompt, install SMPD using the
>>>     "-install" option (Type "smpd -install")
>>>     # Try running mpiexec from the admin command prompt (Type
>>>     "mpiexec -n 2 hostname")
>>>     # Try running mpiexec from a normal command prompt (Type
>>>      Let us know the results.
>>>     Regards,
>>>     Jayesh
>>>     ----- Original Message -----
>>>     From: "Michael Warthon" <michael.warthon at upr.edu
>>>     <mailto:michael.warthon at upr.edu>>
>>>     To: "Jayesh Krishna" <jayesh at mcs.anl.gov
>>>     Cc: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>>>     Sent: Thursday, November 17, 2011 10:10:28 AM
>>>     Subject: Re: [mpich-discuss] Segmentation Fault when running any
>>>     application.
>>>     Alright. Attached is the text file with the complete message
>>>     from the command: "c:\Program Files\MPICH2\bin\mpiexec" -verbose
>>>     -n 2 hostname
>>>     I tried the other command and for some reason I am actually able
>>>     to run the program even when the errors occur. This is the
>>>     response I got when running the command:
>>>     C:\Users\Mike>"c:\Program Files\MPICH2\bin\mpiexec" -n 2
>>>     "C:\Program Files\MPICH
>>>     2\examples\cpi.exe"
>>>     error closing the left context socket: Error = -1
>>>     Enter the number of intervals: (0 quits) 100
>>>     pi is approximately 3.1416009869231241, Error is 0.0000083333333309
>>>     wall clock time = 0.000541
>>>     pi is approximately 3.1424259850010983, Error is 0.0008333314113051
>>>     wall clock time = 0.000047
>>>     Enter the number of intervals: (0 quits) 0
>>>     op_read error on left context: Error = -1
>>>     unable to read the cmd header on the left context, Error = -1
>>>     Error posting readv, An existing connection was forcibly closed
>>>     by the remote ho
>>>     st.(10054)
>>>     On Thu, Nov 17, 2011 at 9:56 AM, Jayesh Krishna <
>>>     jayesh at mcs.anl.gov <mailto:jayesh at mcs.anl.gov> > wrote:
>>>     Hi,
>>>     Yes, please give us the output of the command with "-verbose"
>>>     turned on.
>>>     And for these tests, run mpiexec with the complete path
>>>     ("c:\Program Files\MPICH2\bin\mpiexec" -verbose -n 2 hostname).
>>>     Do you get the same error message when executing cpi
>>>     ("c:\Program Files\MPICH2\bin\mpiexec" -n 2 "C:\Program
>>>     Files\MPICH2\examples\cpi.exe")?
>>>     Regards,
>>>     Jayesh
>>>     From: "Michael Warthon" < michael.warthon at upr.edu
>>>     <mailto:michael.warthon at upr.edu> >
>>>     To: "Jayesh Krishna" < jayesh at mcs.anl.gov
>>>     Sent: Thursday, November 17, 2011 9:42:42 AM
>>>     application.
>>>     For each command, this is the entire response that I get:
>>>     C:\Users\Mike>mpiexec -validate
>>>     SUCCESS
>>>     C:\Users\Mike>mpiexec -n 2 hostname
>>>     Mike-PC
>>>     Mike-PC
>>>     C:\Users\Mike>
>>>     Did you want me to use the verbose option?
>>>     On Thu, Nov 17, 2011 at 9:21 AM, Jayesh Krishna <
>>>     Hi,
>>>     Please copy-paste the command and the response (the complete
>>>     message) in your email.
>>>     Are you able to validate the registered username/password (Type
>>>     "mpiexec -validate" and it should return "SUCCESS")?
>>>     Regards,
>>>     Jayesh
>>>     Sent: Thursday, November 17, 2011 7:50:25 AM
>>>     application.
>>>     Ok. I have checked and yes smpd is running and I have given a
>>>     sufficient username and password so that mpiexec will run. Now I
>>>     am getting a new error when executing mpiexec -n 2 hostname
>>>     where it is giving me this response:
>>>     On Wed, Nov 16, 2011 at 2:21 PM, Jayesh Krishna <
>>>     Hi,
>>>     1. Make sure that the process manager, smpd, is running in your
>>>     system (Look in the task manager/Process Explorer to see if
>>>     there is a service named smpd running. Alternately you can run
>>>     "smpd -status" to check if smpd is running)
>>>     2. Run a simple non-MPI program like hostname from the command
>>>     prompt using mpiexec (Type "mpiexec -n 2 hostname" ). When
>>>     prompted for username/password give a valid Windows
>>>     username/password.
>>>     If mpiexec gives you an error, type "mpiexec -remove" to remove
>>>     the existing registered username/password and then type "mpiexec
>>>     -register" to register a new/valid Windows username/password.
>>>     Re-run mpiexec.
>>>     3. Run the sample MPI program, cpi.exe, provided with MPICH2
>>>     (mpiexec -n 2 C:\Progra~1\MPICH2\examples\cpi.exe)
>>>     >> I am getting an error when I look at the MPICH2 configurable
>>>     settings ...
>>>     This is a known bug. Due to limited developer bandwidth we
>>>     haven't been able to address this issue yet.
>>>     Regards,
>>>     Jayesh
>>>     Sent: Wednesday, November 16, 2011 12:27:01 PM
>>>     application.
>>>     Alright. I have reinstalled MPICH2 using the method in section
>>>     9.4. However, I am not able to connect to the host it seems. I
>>>     keep receiving this message when trying to execute a program:
>>>     Credentials for Mike rejected connecting to Mike-PC
>>>     Aborting: Unable to connect to Mike-PC
>>>     Also, I am getting an error when I look at the MPICH2
>>>     configurable settings that says that MPICH2 is not installed or
>>>     that it cannot query the host.
>>>     On Wed, Nov 16, 2011 at 9:35 AM, Jayesh Krishna <
>>>     Hi,
>>>     Looks like MPICH2 was not installed correctly in your system.
>>>     Uninstall your existing version of MPICH2. Please follow the
>>>     steps in Section 9.4 (Not 9.1 -
>>>     http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf
>>>     ) of the installer's guide to install MPICH2.
>>>     (PS: I am assuming that you have Win7/Srv2008/...)
>>>     Regards,
>>>     Jayesh
>>>     Sent: Tuesday, November 15, 2011 9:04:57 PM
>>>     application.
>>>     Yeah it must have been that I got the installation mixed up. I
>>>     downloaded the windows installer and it finally compiled. So
>>>     progess has been made as now I am getting this error when trying
>>>     to run hello.exe:
>>>     Error while connecting to host, No connection could be made
>>>     because the target m
>>>     achine actively refused it. (10061)
>>>     Connect on sock (host=localhost, port=8676) failed, exhaused all
>>>     end points
>>>     Unable to connect to 'localhost:8676',
>>>     sock error: Error = -1
>>>     On Tue, Nov 15, 2011 at 5:12 PM, Jayesh Krishna <
>>>     Hi,
>>>     There are two ways you can use MPICH2 on Windows+cygwin,
>>>     # Download MPICH2 source compile/install it on Cygwin. Use mpicc
>>>     to compile and use mpiexec (from this installation - NOT the one
>>>     available with Windows installer) to run your program.
>>>     # Download MPICH2 Windows installer, install MPICH2 (using
>>>     installer gui). Use the cygwin/gcc libs provided with the
>>>     Windows installation to compile your code. Use mpiexec from the
>>>     Windows installation to run your job.
>>>     Looks like you are mixing the approaches.
>>>     Regards,
>>>     Jayesh
>>>     Sent: Tuesday, November 15, 2011 1:03:02 PM
>>>     application.
>>>     I was using mpicc in order to compile it. Unfortunately I am
>>>     still not able to compile the code even with the command you
>>>     gave me. I used:
>>>     gcc -l/mpich_install/include -L/mpich_install/lib hello.c -lmpi
>>>     I still received the same error. Did I install it incorrectly maybe?
>>>     On Tue, Nov 15, 2011 at 12:42 PM, Jayesh Krishna <
>>>     Hi,
>>>     How were you compiling your code before ?
>>>     A command similar to,
>>>     "gcc -I/cygdrive/c/Progra~1/MPICH2/include
>>>     -L/cygdrive/c/Progra~1/MPICH2/lib hello.c -o hello.exe -lmpi"
>>>     should work.
>>>     Regards,
>>>     jayesh
>>>     Sent: Tuesday, November 15, 2011 12:18:43 PM
>>>     application.
>>>     Alright. Well I tried it and for some reason it is not able to
>>>     see the library.
>>>     I used the command:
>>>     gcc -g hello.c -L\mpich_install\lib -lmpi
>>>     It ended up giving me an error saying:
>>>     fatal error: mpi.h: No such file or directory
>>>     On Tue, Nov 15, 2011 at 10:32 AM, Jayesh Krishna <
>>>     Hi,
>>>     Try using gcc (usual gcc stuff: specify include dirs using "-I",
>>>     lib dirs using "-L") to compile your code and link it with "-lmpi" .
>>>     Regards,
>>>     Jayesh
>>>     Sent: Tuesday, November 15, 2011 10:16:00 AM
>>>     application.
>>>     What would be the correct command to use in cygwin in order to
>>>     compile the code? Just want to make sure that I actually
>>>     compiled it correctly.
>>>     On Tue, Nov 15, 2011 at 10:10 AM, Jayesh Krishna <
>>>     Hi,
>>>     I just tried compiling your code with cygwin gcc (3.4.4) +
>>>     MPICH2 1.4.1p1 gcc libs and it worked for me (No seg fault,
>>>     gives the expected output).
>>>     Make sure that you are using the correct header files and
>>>     libraries (MPICH2 libs and headers) when you compile your code.
>>>     Regards,
>>>     Jayesh
>>>     Sent: Tuesday, November 15, 2011 9:53:32 AM
>>>     application.
>>>     Ah sorry. I forgot to include the p1 at the end of it. I am
>>>     using mpich2 1.4.1p1
>>>     On Tue, Nov 15, 2011 at 9:44 AM, Jayesh Krishna <
>>>     Did you try the latest stable release (1.4.1p1)?
>>>     -Jayesh
>>>     To: mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>>>     Sent: Monday, November 14, 2011 7:54:43 PM
>>>     Subject: [mpich-discuss] Segmentation Fault when running any
>>>     application.
>>>     Hello,
>>>     I am new to MPI and I went and installed mpich2 1.4.1 onto a
>>>     windows system that is being used through cygwin. I have
>>>     compiled the code that simply prints the process and rank as
>>>     shown below.
>>>     #include <stdio.h>
>>>     #include <mpi.h>
>>>     int main( int argc, char *argv[]) {
>>>     int numprocs, rank, namelen;
>>>     char processor_name[MPI_MAX_PROCESSOR_NAME];
>>>     MPI_Init(&argc, &argv);
>>>     MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
>>>     MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>>>     MPI_Get_processor_name(processor_name, &namelen);
>>>     printf( "Process %d on %s out of %d\n" , rank, processor_name,
>>>     numprocs);
>>>     MPI_Finalize();
>>>     Nothing too complicated. However, I still receive an error from
>>>     the command line in cygwin that simply reads segmentation fault:
>>>     (core dumped). The command I used was:
>>>     mpiexec -n 1 a.exe
>>>     No matter what executable I try to run, I still receive the same
>>>     error. Any help regarding this would be greatly appreciated!
>>>     _______________________________________________
>>>     mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>     To manage subscription options or unsubscribe:
>>>     https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> mpich-discuss mailing listmpich-discuss at mcs.anl.gov  <mailto:mpich-discuss at mcs.anl.gov>
>> Dr. Jose G. Marques
>> Reactor Manager
>> Instituto Tecnologico e Nuclear     phone:  (+351) 219 946 115
>> Estrada Nacional 10                 fax:    (+351) 219 941 039
>> P-2686-953 Sacavem, Portugal
Dr. Jose G. Marques
Reactor Manager
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111117/9207590e/attachment-0001.htm>
