[mpich-discuss] MPICH2 for ARM
    Harald Schuster
    schuster at technikum-wien.at
    Mon Nov 14 05:59:58 CST 2011
Hi
When I use the version mpich2-1.3.2 with the process manager hydra and I
run he "mpirun /bin/hostname" command i got the following error:
[mpiexec at da830] HYDU_create_process
(/mnt/ti_am1707_root/home/default/mpich2-1.3.2/src/pm/hydra/utils/launch/launch.c:69):
execvp error on file ssh (No such file or directory)
Do I need ssh when I use hydra and ch3:sock?!
Harald
On 11.11.2011 22:51, Pavan Balaji wrote:
> Does the following command work:
> % mpirun /bin/hostname
> If this gets a segmentation fault, the problem might be with mpirun.
> In this case, you can try to debug it using:
> % gdb mpirun
> (gdb) r /bin/hostname
>  -- Pavan
> On 11/11/2011 03:31 AM, Harald Schuster wrote:
>> Hi
>> I now tried the cpi example from the mpich2 sources and I also got a
>> segmentation fault. I used the following configuration:
>> CFLAGS="-static" CC=arm-linux-gcc ./../configure
>> --prefix=/mnt/ti_am1707_root/usr/mpich2-install --with-pm=hydra
>> --disable-f77 --disable-fc --disable-cxx --enable-g=dbg,mem,log
>> --with-device=ch3:sock --host=arm-linux
>> How is it possible to trace the execution of the program?!
>> On 10.11.2011 16:33, Harald Schuster wrote:
>>> I added the config.log to this mail but i changed the pm from hydra to
>>> gforker only for testing and know the helloWorld example runs but when
>>> I tried a example with a broadcast the programm stops without any
>>> error but it not finishes. The gforker and hydra uses sockets or?
>>> On 10.11.2011 16:12, Jeff Hammond wrote:
>>>> I think it will help if you post config.log.
>>>> Can you run the test that fails within GDB or Valgrind? I do not
>>>> think that mpirun itself is segfaulting, but rather that it activates
>>>> the code path that does. Maybe this much was clear to you already.
>>>> Jeff
>>>> On Thu, Nov 10, 2011 at 3:33 AM, Harald Schuster
>>>> <schuster at technikum-wien.at> wrote:
>>>>> Hi
>>>>> I use MPICH2 on my normal Linux PC and it works fine. My next goal
>>>>> is to run
>>>>> MPICH2 on a arm926 (am1707) which is simulated in SimSoc and where a
>>>>> normal
>>>>> linux OS is running. The linux is compiled with the buildroot
>>>>> 2010.05 and I
>>>>> use the arm-linux-gcc 4.3.4. I tried to make the the mpich2 with the
>>>>> arm-linux-gcc and it works. I used the following configuration:
>>>>> --disable-f77 --disable-fc --disable-cxx --disable-sharedlibs
>>>>> --host=arm-linux --with-device=ch3:sock
>>>>> Also the make install process works fine. Then I compiled a small
>>>>> helloWorld
>>>>> example with the mpicc for arm and it also works. When I run the
>>>>> helloWorld
>>>>> example on the simulated processor I always got an segmentation
>>>>> fault. For
>>>>> starting the program I use the following command:
>>>>> mpirun -np 1 helloWorld
>>>>> When I start the helloWorld program without the mpirun command I got
>>>>> the
>>>>> right output. So I think the segmentation fault is caused by the
>>>>> mpirun
>>>>> command but I don't know where and what I can do to solve the
>>>>> problem.
>>>>> Best regards
>>>>> Harald
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> mpich-discuss mailing listmpich-discuss at mcs.anl.gov
