[mpich-discuss] problem with collective on sub-communicator
    Miguel Oliveira
    m.a.oliveira at coimbra.lip.pt
    Thu Nov 10 22:12:03 CST 2011
Sorry, sent the version with the only correction I found that makes it work. Remove the MPI_Barrier(world) in both the master and the slaves and you should be able to reproduce the problem.
Cheers,
MAO
On Nov 11, 2011, at 03:31 , Pavan Balaji wrote:
> The test code you sent seems to work fine for me. I don't see any such problem.
> -- Pavan
> On 11/10/2011 03:14 PM, Miguel Oliveira wrote:
>> Hi all,
>> I wrote a very simple master/slave code in MPI and I'm having problems with MPI_Reduce, or even, MPI_Barrier, inside a subset of the world communicator.
>> These operations don't seem to be waiting for all the processes in the subgroup.
>> The code is a straightforward master/slave case where the master generates random numbers when requested and then retrieves a reduction of the sum of these
>> done on the slaves.
>> When run on more than three processes sometimes it happens that the message after the reduction, done from one of the slaves to inform the master of the final
>> result gets to the master before some of the requests for random numbers... This ought to be impossible with a blocking reduction...
>> Am I missing something?
>> Code is attached.
>> Help is appreciated.
>> Cheers,
>> MAO
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111111/b92bd1d4/attachment.bin>
