[mpich-discuss] Simplest way to run mpiexec
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Nov 10 16:31:13 CST 2011
 If you are not too concerned about performance, you can compile MPICH2 on Cygwin and use it (The default process manager would be Hydra - not SMPD).
 If you need it to run on Windows, SMPD is the supported (only) process manager.
Jayesh
----- Original Message -----
Sent: Thursday, November 10, 2011 3:18:09 PM
Subject: [mpich-discuss] Simplest way to run mpiexec
I am new to mpich2.  Looking for a solution that works with
mingw32-gfortran.
Is there a way to run an mpi program with just one line, like
   mpiexec -np 2 myprog.exe
Or is it required that one go through registration and use smpd.exe?
Thx.....John Cary
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
