[mpich-discuss] Build in Solaris 10 x86 HELP...
    renato at dokfile.com
    Tue Nov  8 16:12:21 CST 2011
Hi Dave,
The second option is not for me, I cant upgrade it.
> A heavier weight option would beto upgrade your GCC and assembler packages so that the fancier assemblycode is understood correctly. I personally wouldn't bother with this,but it should work.
 I am not an advanced Guy on Assembly. I will try.
> In the short run, you should be able toget unstuck by editing 12 of that file to read "#if 0" instead. If therelevant section of the configure.in file was written correctly thenthere would be other easy ways to get around this, but unfortunately itappears to be buggy.
Can you giveme more detail, that show how I do this...
Thanks
-----Original Message-----
Sent: Tuesday, November 8, 2011 02:08 PM
Subject: Re: [mpich-discuss] Build in Solaris 10 x86 HELP...
for the archives: http://trac.mcs.anl.gov/projects/mpich2/ticket/1545On Nov 8, 2011, at 1:03 PM CST, Dave Goodell wrote:> It looks like the assembler on your machine doesn't like some of the enhanced memcpy code that we've written into nemesis. This appears to be a Solaris on x86 machine, and the configure script decides that x86 assembly is supported by the assembler by using a small test program. Unfortunately, the assembler does not support a more complicated hunk of inline assembly listed here:> > http://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/tags/release/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_memdefs.h> > In the short run, you should be able to get unstuck by editing 12 of that file to read "#if 0" instead. If the relevant section of the configure.in file was written correctly then there would be other easy ways to get around this, but unfortunately it appears to be buggy.> > A heavier weight option would be to upgrade your GCC and assembler packages so that the fancier assembly code is understood correctly. I personally wouldn't bother with this, but it should work.> > In the long run we should probably make the configure test more robust, and also add a "--disable-asm-memcpy" option or similar so that no code editing is required. I'll add a ticket for this in trac.> > -Dave> > On Nov 8, 2011, at 11:57 AM CST, renato at dokfile.com wrote:> >> Hi All,>> >> I am tring build MPICH2 in Solaris 10, and I dont have success.>> >> Fist I have problems in configuration, now I put it to work, but now I have problems in build.>> >> Whell, this is what I did ->>> >> ./configure CC=gcc CXX=g++ --disable-f77 --disable-fc --prefix=/MPICH/mpich2-install/ 2>&1 | tee c.txt>> >> The result is OK, see ->>> >> ..>> Configuration completed.>> -bash-3.00#>> >> Then, I did make ->>> >> make 2>&1 | tee m.txt>> >> Assembler: dataloop.c>> "/var/tmp//ccuee48e.s", line 493 : Syntax error>> Near line: "mov $PREFETCHBLOCK/16, %eax">> "/var/tmp//ccuee48e.s", line 501 : Syntax error>> Near line: "mov $PREFETCHBLOCK/8, %eax">> make[5]: ** [dataloop.o] Erro 1>> make[5]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'>> make[4]: ** [all-redirect] Erro 2>> make[4]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype'>> make[3]: ** [all-redirect] Erro 2>> make[3]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common'>> make[2]: ** [all-redirect] Erro 2>> make[2]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid'>> make[1]: ** [all-redirect] Erro 2>> make[1]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src'>> make: ** [all-redirect] Erro 2>> -bash-3.00#>> >> And error.>> >> What is wrong..?>> >> Thank you...>> >> >> _______________________________________________>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov>> To manage subscription options or unsubscribe:>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss> > _______________________________________________> mpich-discuss mailing list mpich-discuss at mcs.anl.gov> To manage subscription options or unsubscribe:> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss_______________________________________________mpich-discuss mailing list mpich-discuss at mcs.anl.govTo manage subscription options or unsubscribe:https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/56860532/attachment-0001.htm>
