[mpich-discuss] Build in Solaris 10 x86 HELP...
    renato at dokfile.com
    Tue Nov  8 16:02:18 CST 2011
 Ok Dave, thaks...I'll wait for...
-----Original Message-----
Sent: Tuesday, November 8, 2011 02:08 PM
Subject: Re: [mpich-discuss] Build in Solaris 10 x86 HELP...
for the archives: http://trac.mcs.anl.gov/projects/mpich2/ticket/1545On Nov 8, 2011, at 1:03 PM CST, Dave Goodell wrote:> It looks like the assembler on your machine doesn't like some of the enhanced memcpy code that we've written into nemesis. This appears to be a Solaris on x86 machine, and the configure script decides that x86 assembly is supported by the assembler by using a small test program. Unfortunately, the assembler does not support a more complicated hunk of inline assembly listed here:> > http://trac.mcs.anl.gov/projects/mpich2/browser/mpich2/tags/release/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include/mpid_nem_memdefs.h> > In the short run, you should be able to get unstuck by editing 12 of that file to read "#if 0" instead. If the relevant section of the configure.in file was written correctly then there would be other easy ways to get around this, but unfortunately it appears to be buggy.> > A heavier weight option would be to upgrade your GCC and assembler packages so that the fancier assembly code is understood correctly. I personally wouldn't bother with this, but it should work.> > In the long run we should probably make the configure test more robust, and also add a "--disable-asm-memcpy" option or similar so that no code editing is required. I'll add a ticket for this in trac.> > -Dave> > On Nov 8, 2011, at 11:57 AM CST, renato at dokfile.com wrote:> >> Hi All,>> >> I am tring build MPICH2 in Solaris 10, and I dont have success.>> >> Fist I have problems in configuration, now I put it to work, but now I have problems in build.>> >> Whell, this is what I did ->>> >> ./configure CC=gcc CXX=g++ --disable-f77 --disable-fc --prefix=/MPICH/mpich2-install/ 2>&1 | tee c.txt>> >> The result is OK, see ->>> >> ..>> Configuration completed.>> -bash-3.00#>> >> Then, I did make ->>> >> make 2>&1 | tee m.txt>> >> Assembler: dataloop.c>> "/var/tmp//ccuee48e.s", line 493 : Syntax error>> Near line: "mov $PREFETCHBLOCK/16, %eax">> "/var/tmp//ccuee48e.s", line 501 : Syntax error>> Near line: "mov $PREFETCHBLOCK/8, %eax">> make[5]: ** [dataloop.o] Erro 1>> make[5]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'>> make[4]: ** [all-redirect] Erro 2>> make[4]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype'>> make[3]: ** [all-redirect] Erro 2>> make[3]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common'>> make[2]: ** [all-redirect] Erro 2>> make[2]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid'>> make[1]: ** [all-redirect] Erro 2>> make[1]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src'>> make: ** [all-redirect] Erro 2>> -bash-3.00#>> >> And error.>> >> What is wrong..?>> >> Thank you...>> >> >> _______________________________________________>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov>> To manage subscription options or unsubscribe:>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss> > _______________________________________________> mpich-discuss mailing list mpich-discuss at mcs.anl.gov> To manage subscription options or unsubscribe:> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss_______________________________________________mpich-discuss mailing list mpich-discuss at mcs.anl.govTo manage subscription options or unsubscribe:https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/0ac55cd5/attachment.htm>
