[mpich-discuss] Build in Solaris 10 x86 HELP...
    renato at dokfile.com
    Tue Nov  8 11:57:37 CST 2011
Hi All,
I am tring build MPICH2 in Solaris 10, and I dont have success.
Fist I have problems in configuration, now I put it to work, but now I have problems in build.
Whell, this is what I did ->
./configure CC=gcc CXX=g++ --disable-f77 --disable-fc --prefix=/MPICH/mpich2-install/ 2>&1 | tee c.txt
The result is OK, see ->
Configuration completed.
-bash-3.00#
Then, I did make ->
make 2>&1 | tee m.txt
Assembler: dataloop.c
 "/var/tmp//ccuee48e.s", line 493 : Syntax error
 Near line: "mov $PREFETCHBLOCK/16, %eax"
 "/var/tmp//ccuee48e.s", line 501 : Syntax error
 Near line: "mov $PREFETCHBLOCK/8, %eax"
make[5]: ** [dataloop.o] Erro 1
make[5]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'
make[4]: ** [all-redirect] Erro 2
make[4]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common/datatype'
make[3]: ** [all-redirect] Erro 2
make[3]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid/common'
make[2]: ** [all-redirect] Erro 2
make[2]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src/mpid'
make[1]: ** [all-redirect] Erro 2
make[1]: Saindo do diretório `/MPICH/Source/mpich2-1.4.1p1/src'
make: ** [all-redirect] Erro 2
-bash-3.00#
And error.
What is wrong..?
Thank you...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/cc5d3721/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/cc5d3721/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/cc5d3721/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/cc5d3721/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111108/cc5d3721/attachment-0007.obj>
