[mpich-discuss] Fwd: configure: error: unable to determine matching C type for C++ bool
    renato at dokfile.com
    Tue Nov  1 12:47:50 CDT 2011
My libstdc++.so.6 is in /usr/sfw/lib
-bash-3.00# ls /usr/sfw/lib/libstdc++.so*
/usr/sfw/lib/libstdc++.so /usr/sfw/lib/libstdc++.so.6.0.3
-bash-3.00#
How to I tell this to MPI configurator? Have any way?
Thanks
-----Original Message-----
Sent: Tuesday, November 1, 2011 12:42 PM
Subject: Re: [mpich-discuss] Fwd: configure: error: unable to determine matching C type for C++ bool
Your g++ does not work either, same error as before. It is possibleyour c++ is just g++. If you don't need C++ support, you could disableit by adding --disable-cxx to your configure command. If you do need C++support, you need to find out why libstdc++.so.6 isn't there...configure:40496: g++ -o conftest -O2 -I/MPICH/Source/mpich2-1.4.1p1/src/mpl/include -I/MPICH/Source/mpich2-1.4.1p1/src/mpl/include -I/MPICH/Source/mpich2-1.4.1p1/src/openpa/src -I/MPICH/Source/mpich2-1.4.1p1/src/openpa/src conftest.cpp >&5configure:40500: $? = 0configure:40506: ./conftestld.so.1: conftest: fatal: libstdc++.so.6: open failed: No such file or directory./configure: line 40508: 2921 Killed ./conftest$ac_exeextconfigure:40510: $? = 137configure: program exited with status 137A.Chan----- Original Message -----> Sorry again,> > Follows...> > -----Original Message-----> From: Anthony Chan [mailto:chan at mcs.anl.gov]> Sent: Tuesday, November 1, 2011 11:59 AM> To: mpich-discuss at mcs.anl.gov> Subject: Re: [mpich-discuss] Fwd: configure: error: unable to> determine matching C type for C++ bool> > ----- Original Message -----> > -bash-3.00# ./configure CC=gcc CXX=g++> --disable-f77 --disable-fc> --prefix=/MPICH/mpich2-install/ 2>&1 | tee> c.txt> > This is correct?> > Dont work :0(You need to send us your> c.txt and config.log to show what went> wrong.A.Chan_______________________________________________mpich-discuss> mailing list mpich-discuss at mcs.anl.govTo manage subscription options> or> unsubscribe:https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss> > _______________________________________________> mpich-discuss mailing list mpich-discuss at mcs.anl.gov> To manage subscription options or unsubscribe:> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss_______________________________________________mpich-discuss mailing list mpich-discuss at mcs.anl.govTo manage subscription options or unsubscribe:https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111101/43bcb942/attachment.htm>
