[mpich-discuss] configure: error: unable to determine matching C type for C++ bool
    renato at dokfile.com
    Tue Nov  1 08:52:51 CDT 2011
 Hi Thanks for help!
Follows c.txt (log)
-----Original Message-----
Sent: Tuesday, November 1, 2011 09:48 AM
Cc: renato at dokfile.com
Subject: Re: [mpich-discuss] configure: error: unable to determine matching C type for C++ bool
Hello,Can you send us the output logs as described in the README? -- PavanOn 11/01/2011 08:42 AM, renato at dokfile.com wrote:> Hi All!>> I am tring build MPICH2 in my solaris 10 box.>> I used this command to configure it:>> # bash> ./configure --disable-f77 --disable-fc --prefix=/MPICH/mpich2-install/> 2>&1 | tee c.txt>> I will use only MPI C++ interface.>> My Solais Box is one VM (Solaris 10 Container) running in one X86.>> My problem is that I received this error:>> ...> checking for _Bool... yes> checking for float _Complex... yes> checking for double _Complex... yes> checking for long double _Complex... yes> checking size of bool... 0> configure: error: unable to determine matching C type for C++ bool>> How I can fix it? Any Idea?>> Thanks for Help>>>> _______________________________________________> mpich-discuss mailing list mpich-discuss at mcs.anl.gov> To manage subscription options or unsubscribe:> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss-- Pavan Balajihttp://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111101/1d93c493/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111101/1d93c493/attachment-0001.obj>
