[mpich-discuss] spawned processes do not shut down
    Jonathan Bishop
    jbishop.rwc at gmail.com
    Tue Nov  1 00:56:27 CDT 2011
Just a follow up.
I discovered that you just need to disconnect from the master side
only, and not on both the worker and master.
Jon
On Fri, Oct 28, 2011 at 8:53 PM, Jonathan Bishop <jbishop.rwc at gmail.com> wrote:
> Thanks!
> On Fri, Oct 28, 2011 at 11:17 AM, Darius Buntinas <buntinas at mcs.anl.gov>
> wrote:
>> Hi Jon,
>> I had to pull out my copy of the standard for this one :-).  The standard
>> says (Section 10.5.4 on pg 330) that MPI_Finalize is collective over
>> "connected" processes.  By the definition of "connected" (in the same
>> section), the master and worker processes in your application are still
>> connected, so the worker process might wait until the master process calls
>> MPI_Finalize (in the case of MPICH, it will wait if the two processes have
>> ever communicated).  You can use MPI_Comm_disconnect to disconnect the
>> master and worker before the worker calls MPI_Finalize.
>> I added an MPI_Comm_disconnect on line 37 and line 80 of your program and
>> it looks like it works as you intend.
>> -d
>> On Oct 28, 2011, at 11:18 AM, Jonathan Bishop wrote:
>> > I am using MPI_Comm_spawn to dynamically run workers. However, when the
>> > workers exit they get hung up on MPI_Finalize. Here is a short program which
>> > shows the issue...
>> > It responds to several commands...
>> > Do
>> > start
>> > stop
>> > and then check how many processes are running - it should be 1, not 2.
>> > I am using MPICH2 1.4.1-p1.
>> > Thanks,
>> > Jon
>> > #include <sys/types.h>
>> > #include <unistd.h>
>> > #include <iostream>
>> > #include "mpi.h"
>> > using namespace std;
>> > main(int argc, char **argv)
>> >   MPI_Init(&argc, &argv);
>> >   MPI_Comm parent;
>> >   MPI_Comm_get_parent(&parent);
>> >   // Master
>> >   if (parent == MPI_COMM_NULL) {
>> >     cout << getpid() << endl;
>> >     MPI_Comm intercom = MPI_COMM_NULL;
>> >     while (1) {
>> >       cout << "Enter: ";
>> >       string s;
>> >       cin >> s;
>> >       if (s == "start") {
>> >       if (intercom != MPI_COMM_NULL) {
>> >         cout << "already started" << endl;
>> >         continue;
>> >       MPI_Comm_spawn(argv[0], MPI_ARGV_NULL, 1, MPI_INFO_NULL, 0,
>> > MPI_COMM_SELF, &intercom,  MPI_ERRCODES_IGNORE);
>> >       continue;
>> >       if (s == "stop") {
>> >       if (intercom == MPI_COMM_NULL) {
>> >         cout << "worker not running" << endl;
>> >         continue;
>> >       MPI_Send(const_cast<char*>(s.c_str()), s.size(), MPI_CHAR, 0, 0,
>> > intercom);
>> > //    MPI_Finalize();  // This will allow the workers to die, but then I
>> > can not restart them.
>> >       continue;
>> >       if (s == "exit") {
>> >         cout << "need to stop before exit" << endl;
>> >         continue;
>> >       break;
>> >       cout << "need to start" << endl;
>> >       continue;
>> > intercom);
>> >       char buf[1000];
>> >       MPI_Status status;
>> >       MPI_Recv(buf, 1000, MPI_CHAR, MPI_ANY_SOURCE, MPI_ANY_TAG,
>> > intercom, &status);
>> >       int count;
>> >       MPI_Get_count(&status, MPI_CHAR, &count);
>> >       buf[count] = 0;
>> >       string t = buf;
>> >       cout << "worker returned " << t << endl;
>> >   // Worker
>> >   if (parent != MPI_COMM_NULL) {
>> >     while (1) {
>> >       char buf[1000];
>> >       MPI_Status status;
>> >       MPI_Recv(buf, 1000, MPI_CHAR, MPI_ANY_SOURCE, MPI_ANY_TAG, parent,
>> > &status);
>> >       int count;
>> >       buf[count] = 0;
>> >       string s = buf;
>> >       if (s == "stop") {
>> >       cout << "worker stopping" << endl;
>> >       break;
>> > parent);
>> >   MPI_Finalize();
>> > _______________________________________________
>> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> > To manage subscription options or unsubscribe:
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
