[mpich-discuss] Fatal error in PMPI_Bcast:
    Fujun Liu
    liufujun07 at gmail.com
    Fri May 27 11:51:16 CDT 2011
I also doubt it is a networking problem. I am trying to how to find it.
Anyway, thanks a lot
On Fri, May 27, 2011 at 12:46 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> If your firewall truly is disabled and those /etc/hosts files are accurate,
> then I don't know what the problem might be.  It still sounds like a
> networking problem, but I don't have any concrete suggestions for what else
> to check.
> Perhaps others on the list have experienced these sorts of problems before
> and can offer ideas.
> -Dave
> On May 27, 2011, at 11:24 AM CDT, Fujun Liu wrote:
> > I use two hosts: one is query, the other is trigger
> > (1) about firewall
> > netlab at query:~$ sudo ufw status
> > Status: inactive
> > netlab at trigger:~$ sudo ufw status
> > Status: inactive
> > Both firewalls are turned off.
> > (2)about DNS
> > for query, /etc/hosts is as below:
> > 127.0.0.1       localhost
> > #127.0.1.1      query
> > xxx.xxx.xxx.42  trigger
> > xxx.xxx.xxx.43  query
> > for trigger, /etc/hosts is as below:
> > 127.0.0.1       localhost
> > #127.0.1.1      trigger
> > In fact, they are the same
> > (3) version of MPICH2
> > mpich2-1.3.2p1, it is from
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
> > As you can notice, it is called stable version
> > (4) about configure.
> > I did nothing about this. I just use the -prefix option. Do I need more
> about this?
> > Now hellowworld workds fine on two hosts, cpi works fine on single one
> host. The problem is probably that the two hosts can't communicate. So any
> suggestion?
> > Best Wishes,
> > On Fri, May 27, 2011 at 11:55 AM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> > The problem looks like a networking issue, either a firewall or DNS (bad
> /etc/hosts file?) issue.  Are the firewalls disabled on these machines?  How
> are the hostnames configured?
> > What version of MPICH2 is this?  What configure options did you use when
> you built MPICH2?
> > -Dave
> > On May 27, 2011, at 10:49 AM CDT, Fujun Liu wrote:
> > > The cpi also does not work. There is no error message, but it takes
> forever:
> > > xxxx at query:~/MPI$ mpiexec -n 2 -f machinefile
> /home/netlab/MPI/mpich2-build/examples/cpi
> > > Process 1 of 2 is on query
> > > Process 0 of 2 is on trigger
> > > I think my two hosts are still trying to communicate to each other. Any
> suggestions?
> > > Best wishes,
> > > On Fri, May 27, 2011 at 9:42 AM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> > > Does the "examples/cpi" program from the MPICH2 build directory work
> correctly for you when you run it on multiple nodes?
> > > -Dave
> > > On May 26, 2011, at 5:49 PM CDT, Fujun Liu wrote:
> > > > Hi everyone,
> > > > When I try one example from
> http://beige.ucs.indiana.edu/I590/node62.html, I got the following error
> message as below. In the MPI cluster, there are two hosts. If I run the two
> processes on just one host, everything works fine. But if I run two
> processes on the two-host cluster, the following error happens. I think the
> two hosts just can't send/receive message to each other, but I don't know
> how to resolve this.
> > > > Thanks in advance!
> > > > xxxx at query:~/MPI$ mpiexec -n 2 -f machinefile ./GreetMaster
> > > > Fatal error in PMPI_Bcast: Other MPI error, error stack:
> > > > PMPI_Bcast(1430).......................:
> MPI_Bcast(buf=0x7fff13114cb0, count=8192, MPI_CHAR, root=0, MPI_COMM_WORLD)
> failed
> > > > MPIR_Bcast_impl(1273)..................:
> > > > MPIR_Bcast_intra(1107).................:
> > > > MPIR_Bcast_binomial(143)...............:
> > > > MPIC_Recv(110).........................:
> > > > MPIC_Wait(540).........................:
> > > > MPIDI_CH3I_Progress(353)...............:
> > > > MPID_nem_mpich2_blocking_recv(905).....:
> > > > MPID_nem_tcp_connpoll(1823)............:
> > > > state_commrdy_handler(1665)............:
> > > > MPID_nem_tcp_recv_handler(1559)........:
> > > > MPID_nem_handle_pkt(587)...............:
> > > > MPIDI_CH3_PktHandler_EagerSend(632)....: failure occurred while
> posting a receive for message data (MPIDI_CH3_PKT_EAGER_SEND)
> > > > MPIDI_CH3U_Receive_data_unexpected(251): Out of memory (unable to
> allocate -1216907051 bytes)
> > > > [mpiexec at query] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
> > > > APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
> > > > Fujun Liu
> > > > Department of Computer Science, University of Kentucky, 2010.08-
> > > > fujun.liu at uky.edu, (859)229-3659
> > > > _______________________________________________
> > > > mpich-discuss mailing list
> > > > mpich-discuss at mcs.anl.gov
> > > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > Fujun Liu
> > Fujun Liu
Fujun Liu
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110527/79fd48e6/attachment-0001.htm>
