[mpich-discuss] reading Ascii files using parallel I/o
    Brock Palen
    brockp at umich.edu
    Mon May 23 08:55:05 CDT 2011
Sreenivas,
Note using binary IO tends to be faster as it takes less space for the same amount of data.
You may also want to look at the hdf5/*-parallel modules on Nyx/Flux on campus. I find using hdf5 parallel IO to be simpler and more interoperable (modifiable and readable in matlab/idl with little effort) than invoking MPI-IO directly.
Just my own $0.02 others with more parallel IO experience may have other input.
Brock Palen
www.umich.edu/~brockp
Center for Advanced Computing
brockp at umich.edu
(734)936-1985
On May 23, 2011, at 1:00 AM, Rajeev Thakur wrote:
> MPI-IO doesn't support formatted I/O, i.e., the equivalent of fprintf and fscanf. However you can read/write unformatted character buffers.
> Rajeev
>> Date: Sat, 21 May 2011 23:48:57 -0400
>> From: <vvvnew at umich.edu>
>> Subject: [mpich-discuss] reading Ascii files using parallel I/o
>> To: mpich-discuss at mcs.anl.gov
>> Message-ID: <7f8c0ee756294fb644ab193ff0338e1c at umich.edu>
>> Content-Type: text/plain; charset="UTF-8"
>> Hi,
>> I want to know if there's a general way to read and write ASCII data
>> using parallel input/output. I know there are only 3 Mpi data formats
>> 'Native', 'Internal','External32', none of which support Ascii data. Since
>> all my input data is in ASCII and i also need the output to be in ASCII to
>> increase interoperability with other software, can someone suggest an
>> efficient way to get around this problem. Right now iam sending all the
>> data in and out through one node and makes the scaling pretty bad for large
>> datasets, so parallel i/o with ascii would make my life a whole lot easier.
>> Thanks
>> Sreenivas
> mpich-discuss mailing list
