[mpich-discuss] Blocking MPI_Finalize()
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu May 19 11:10:30 CDT 2011
 Without much information I would recommend that you debug your code and provide us with as much information as possible so that we can help you.
# Can you run the example program cpi.exe provided with MPICH2 ?
# Are you sure (after debugging your code) that all processes call MPI_Finalize() ?
-Jayesh
----- Original Message -----
From: "Cecile Daversin" <daversin at hydrowide.com>
Sent: Thursday, May 19, 2011 10:11:25 AM
Subject: [mpich-discuss] Blocking MPI_Finalize()
My code depends on a lot of header files, so I can't send you an exctract with a test program easily.
I run my job with the following command :
mpiexec -n 4 <my_executable> <executable_parameters>
and I use only one node.
C.
mpich-discuss mailing list
