[mpich-discuss] mpe error
Anthony Chan
chan at mcs.anl.gov
Tue May 17 08:22:40 CDT 2011
When you link with -mpe=mpilog, you don't need -lmpe flag.
MPE generates trace file for each process and merges them during
MPI_Finalize. Can you post your program here if it isn't too big?
A.Chan
----- Original Message -----
> Hi,
> Thanks for the replies! To clarify, my program seems to work when I
> compile and run the program without MPE.
> But as soon as I add the "-mpe=mpilog" and the "-lmpe" flag, I get the
> error message.
> What does "merging" mean?
> Thanks!
> Peter
> > Backtrace shows that merging failed. Would you be able to run
> > the same program without MPE ?
> > A.Chan
> > > Hi,
> > > I'm a newbie to mpi, and i've managed to compile, link and run
> > > my
> > > program under mpich2-1.3.2p1
> > > without any problems. However, when i do the same, but using the
> > > "-mpe=mpilog" option, the following
> > > error is produced:
> > > Writing logfile....
> > > Enabling the Default clock synchronization...
> > > clog_commset.c:CLOG_CommSet_sync_IDs() -
> > > The parent CLOG_CommSet_t does not contain 0-th GID
> > > 1188451318-1305386600.768476-degas.como.group in the
> > > child_table[]/nclog_commset.c:CLOG_CommSet_merge() -
> > > CLOG_CommSet_sync_IDs() fails!
> > > Backtrace of the callstack at rank 2:
> > > At [0]:
> > > LINUXlib/mpsimpleprog_vienna(CLOG_Util_abort+0x73)[0x6e2377]
> > > At [1]:
> > > LINUXlib/mpsimpleprog_vienna(CLOG_CommSet_merge+0x2d2)[0x6dec1f]
> > > At [2]:
> > > LINUXlib/mpsimpleprog_vienna(CLOG_Merger_sort+0x1d)[0x6e9c44]
> > > At [3]:
> > > LINUXlib/mpsimpleprog_vienna(CLOG_Converge_sort+0x20)[0x6e631e]
> > > At [4]:
> > > LINUXlib/mpsimpleprog_vienna(MPE_Finish_log+0x114)[0x6e2144]
> > > At [5]:
> > > LINUXlib/mpsimpleprog_vienna(MPI_Finalize+0x58c)[0x6b228a]
> > > At [6]:
> > LINUXlib/mpsimpleprog_vienna(_ZN5boost3mpi11environmentD1Ev+0x63)[0x69dc53]
> > > At [7]: LINUXlib/mpsimpleprog_vienna(main+0x56e)[0x5909d6]
> > > At [8]: /lib64/libc.so.6(__libc_start_main+0xe6)[0x3e4c21e576]
> > > At [9]: LINUXlib/mpsimpleprog_vienna[0x58fca9]
> > > application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
> > > [mpiexec at degas.como.group] ONE OF THE PROCESSES TERMINATED
> > > BADLY:
> > > CLEANING UP
> > > APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal
> > > 15)
> > > Please help!
> > > Thanks,
> > > Peter
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Peter Man University of Cambridge,
> Department of Chemical Engineering
> and Biotechnology,
> Tel. +44 (0)1223 334786 Pembroke Street,
> Fax. +44 (0)1223 334796 Cambridge CB2 3RA, UK
> email: mailto:plwm2 at cam.ac.uk
> mailto:plwm2 at cantab.net
