[mpich-discuss] Parallel quick sort
Mandar Gurav mandarwce at gmail.com
Tue May 17 01:55:06 CDT 2011
Hi Irfan!
This is MPICH discussion mailing list. People here can help you in
MPICH related issues only....
By the way, our work with quick sort revealed that it scales only upto
2 processes. It will not benefit from increasing the number of
processes. It algorithm itself is tuned(?) for serial execution. :( :(
You need to see if you can tweak the algorithm in such a way that it
can scale upto your satisfaction....
-- Mandar Gurav
On 5/17/11, Irfan Gul <hungu.orakzai at gmail.com> wrote:
> #include <mpi.h>
> #include <stdio.h>
> #include <stdlib.h>
> #define  TRUE 1
> #include "math.h"
> #include <time.h>
> int IncOrder(const void *e1, const void *e2 )
>           return (*((int *)e1) - *((int *)e2));
> DisplayError(char *str)
>     printf("Error: %s \n",str);
> int Partition(int *arr, int left, int right) {
> int i = left, j = right;
> int tmp;
> int pivot = arr[(left + right) / 2];
> /* partition */
> while (i <= j) {
> while (arr[i] < pivot)
> i++;
> while (arr[j] > pivot)
> j--;
> if (i <= j) {
> tmp = arr[i];
> arr[i] = arr[j];
> arr[j] = tmp;
> i++;
> j--;
> return j;
> int PowerOf2(int num)
>     int i;
>     i=1;
>     while(num>0)
>         num--;
>         i=i*2;
>     return i;
> PQuickSort(int *Array,int start,int end,int m,int id,int MyRank)
>     int j;
>     int r;
>     int LocalLength;
>     int *tmp;
>     //int newsize;
>     MPI_Status status;
>     LocalLength=-1;
>     if(m==0)
>     if(MyRank==id)
>     qsort(Array, end-start, sizeof *Array, IncOrder);
>     return 0;
> if(MyRank==id)
>     r=Partition(Array,start,end);
>     LocalLength=end-r;
> MPI_Send(&LocalLength,1,MPI_INT,id+PowerOf2(m-1),MyRank,MPI_COMM_WORLD);
> if(LocalLength!=0)
> MPI_Send(Array+r+1,LocalLength,MPI_INT,id+PowerOf2(m-1),MyRank,MPI_COMM_WORLD);
>     if(MyRank==id+PowerOf2(m-1))
>         MPI_Recv(&LocalLength,1,MPI_INT,id,id,MPI_COMM_WORLD,&status);
>        if(LocalLength!=0)
>              tmp=(int *)malloc(LocalLength*sizeof(int));
>              if(tmp==0)
>                  DisplayError("Malloc memory error!");
> MPI_Recv(tmp,LocalLength,MPI_INT,id,id,MPI_COMM_WORLD,&status);
>     j=r-1-start;
>     MPI_Bcast(&j,1,MPI_INT,id,MPI_COMM_WORLD);
>     if(j>0)
>         PQuickSort(Array,start,r-1,m-1,id,MyRank);
>     j=LocalLength;
>     if(j>0)
>         PQuickSort(tmp,0,LocalLength-1,m-1,id+PowerOf2(m-1),MyRank);
>     if((MyRank==id+PowerOf2(m-1)) && (LocalLength!=0))
> MPI_Send(tmp,LocalLength,MPI_INT,id,id+PowerOf2(m-1),MPI_COMM_WORLD);
>     if((MyRank==id) && (LocalLength!=0))
>         MPI_Recv(Array+r+1,LocalLength,MPI_INT,id+PowerOf2(m-1),id+PowerOf2
> (m-1),MPI_COMM_WORLD,&status);
> int LogBase2(int num)
>     int i, j;
>     i=1;
>     j=2;
>     while(j<num)
>         j=j*2;
>         i++;
>     if(j>num)
>         i--;
>     return i;
> main(int argc,char *argv[])
>     int     ArraySize;
>     int     *Array;
>     int    MyRank, npes;
>     int     i;
>     int     m ;
>     double     t1,t2,t3;
>     //MPI_Status status;
>     MPI_Init(&argc,&argv);
>     MPI_Comm_rank(MPI_COMM_WORLD,&MyRank);
>     MPI_Comm_size(MPI_COMM_WORLD,&npes);
>     if(MyRank==0)
>         ArraySize=1000000;
>         printf("%d\n",ArraySize);
>         Array=(int *)malloc(ArraySize*sizeof(int));
>         if(Array==0)
>             printf("Malloc memory error!");
>         srand(396);
>         for(i=0;i<ArraySize;i++)
>             Array[i]=(int)rand()%1000;
>         printf("\n");
>     m=LogBase2(npes);
>     MPI_Bcast(&ArraySize,1,MPI_INT,0,MPI_COMM_WORLD);
>         t1=MPI_Wtime();
>     PQuickSort(Array,0,ArraySize-1,m,0,MyRank);
>         t2=MPI_Wtime();
>         t3=t2-t1;
>     if(MyRank==0)
>             printf("%10d",Array[i]);
>                 printf("\t");
>         printf("\n");
>     printf("MPI_time :%6.3f\n",t3);
>     MPI_Finalize();
>     return 0;
> when I increase the number of process this code take more time. :(
Mandar Gurav
http://www.mandargurav.org
