[mpich-discuss] MPICH2,	ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
    Wei Huang
    huangwei at ucar.edu
    Sat May 14 16:31:52 CDT 2011
Hi, there,
I am trying install mpich2-1.4rc2 on a Linux cluster with pgi.
When I use an old version (6.2.5) of PGI to build, the mpi example worked fine.
(But have problem to build other software.)
But with a new version (8.0.4), after the build, when I run the example
program, I got seg. fault with w processors.
Anyone knows what is wrong here?
Wei
mpiexec -n 1 ./cpi
Process 0 of 1 is on neem
pi is approximately 3.1415926544231341, Error is 0.0000000008333410
wall clock time = 0.000275
mpiexec -n 2 ./cpi
Process 1 of 2 is on neem
Process 0 of 2 is on neem
pi is approximately 3.1415926544231318, Error is 0.0000000008333387
wall clock time = 0.000192
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 11
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
