[mpich-discuss] how to make the hosts files
Leon Yuhanov
leon at philipchun.com
Thu May 12 05:48:17 CDT 2011
is there any way to do this with mpd instead???
Leon Yuhanov
IT Manager - Philip Chun Advanced Technology
Cell: +614 16 029 852
Email: leon at philipchun.com
Mandar Gurav <mandarwce at gmail.com> wrote:
I would suggest you to consult this page....
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
--Mandar Gurav
On Thu, May 12, 2011 at 4:02 PM, Leon Yuhanov <leon at philipchun.com> wrote:
> is there a way to run this process on multiple machines without a file??
> Leon Yuhanov
> Ohhh!
> You are running your job on a single machine! Just forget about the
> machinefile and all. Just execute
> "mpiexec -np 2 ./a.out"
> that's it.
> The machinefile or hosts file is required when you have 2(or more)
> machines with mpi installed on both machines and you want to run a
> single program the spawns across the two machines.
> -- Mandar Gurav
> On Thu, May 12, 2011 at 2:03 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
>> Is there an actual machine with the name "host1" or "host2" in your setup?
>> If you are just running it on the local node, you should not give the
>> -machinefile or -f option.
>> -- Pavan
>> On 05/12/2011 03:28 AM, hyunduk kim wrote:
>>> Thanks for your response
>>> However, my setup is not working.
>>> In my check progress.
>>> 1) I installed mpich2 on intel muti-core 2 cpu machine
>>> 2) check : /etc/hosts file
>>> 127.0.0.1 localhost.localdomain localhost
>>> ::1 localhost6.localdomain6 localhost6
>>> 3) made the machinefile for mpiexec :
>>> /usr/local/mpich2/machine/machinefile
>>> host1:6
>>> host2:6
>>> 4) run : [root at francium machine]# mpiexec -n 10 -machinefile
>>> ./machinefile /usr/local/mpich2-1.3.2p1/examples/cpi
>>> ==> I received messages as below
>>> ssh: connect to host host1 port 22: Connection timed out
>>> ssh: connect to host host2 port 22: Connection timed out
>>> Question is :
>>> 1) why do I setup passwordless login among the two hosts?
>>> 2) Mpich2 was installed on the just multi-core 2 cpu machine. Why dose
>>> the mpiexec try to connect host1 and host2 using port 22 ?
>>> 3) Is there other method for defining the machinefile on the multi-core
>>> 2 cpu machine ?
>>> I will attach my log files.
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
> Mandar Gurav
> http://www.mandargurav.org
Mandar Gurav
