[mpich-discuss] lnk 2019 error, hellow world on windows 7 (64bit), VS2008
    Ryan Price
    ryprice00 at gmail.com
    Mon May  9 11:09:59 CDT 2011
No I haven't had a chance to follow section 9.4 but I installed from the
binaries as an administrator previously. I plan to reinstall VS2008 with the
64 bit components installed and reinstall the x64 version of MPICH2 and then
I'll report back. I suspect that is the cause of my problems but won't have
any free time to reinstall until my current project is finished.
Ryan
On Mon, May 9, 2011 at 7:36 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
>  Did you follow the instructions in Section 9.4 ? The instructions allow
> you to install MPICH2 as an administrator.
> -Jayesh
> From: "John A. Biddiscombe" <biddisco at cscs.ch>
> To: mpich-discuss at mcs.anl.gov
> Sent: Friday, May 6, 2011 4:18:41 AM
> Subject: Re: [mpich-discuss] lnk 2019 error, hellow world on windows 7
> (64bit), VS2008
> Last time I installed on windows (7) the service was not started/installed
> during setup and I had to manually do it.
> I expect that's what's in the instructions referred to below.
> JB
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:
> mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
> Sent: 05 May 2011 17:03
> To: Ryan Price
> Cc: mpich-discuss at mcs.anl.gov
> (64bit), VS2008
> Hi,
>  There seems to be some problem with the MPICH2 installation. Uninstall
> MPICH2 and try the steps mentioned in the Section 9.4 (NOT 9.1) of the
> MPICH2 installer's guide (
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs)
> to install MPICH2.
> (PS: Usually the VS installations have support for building 64-bit
> applications. I would recommend building 64-bit apps with VS.)
> Regards,
> Jayesh
> From: "Ryan Price" <ryprice00 at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Sent: Tuesday, May 3, 2011 12:28:51 PM
> (64bit), VS2008
> Thanks for your reply Jayesh.
> I had the 64bit version of MPICH2 installed but do not have the 64bit
> components enabled in VS. So I decided to try uninstalling the 64bit version
> of MPICH2 and installed the 32bit version.
> I tried running my helloworld program again and am no longer getting the
> linker error I was previously :) Unfortunately I know get another error :(
> Error while connecting to host, No connection could be made because the
> target machine actively refused it. (10061)
> Connect on sock (host= my.host.name , port=8678) failed, exhaused all end
> points
> Unable to connect to ' my.host.name:8678 ',
> sock error: Error = -1
> Maybe I didn't configure something correctly during setup. I would have
> thought this was due to the firewall but I did make sure that mpiexec and
> smpd are not blocked by windows firewall. Maybe I just need to bite the
> bullet and reinstall VS with 64bit components enabled and reinstall the
> 64bit version of MPICH2.
> On Mon, May 2, 2011 at 8:19 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> # Make sure that you installed the 64-bit version of MPICH2.
> # Make sure that you select the "solution platform" in VS to be "x64"
> (Usually the default one is "Win32" . There should be a drop-down box on the
> top of the VS interface that allows you to select the "solution platform" -
> You might have to select "Configuration Manager" and create a new "Active
> Solution platform". You might find more help in the VS help docs.)
> # Make sure that the paths specified to MPICH2 libs are correct.
> -Jayesh
> From: "Ryan Price" < ryprice00 at gmail.com >
> Sent: Sunday, May 1, 2011 6:08:14 PM
> Subject: [mpich-discuss] lnk 2019 error, hellow world on windows 7 (64bit),
> VS2008
> Hi,
> I'm just trying to get a mpi hello world program up and running and can't
> seem to get it to build properly. I'm on windows7 using VS2008.
> I get this error:
> 1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Finalize
> referenced in function _main
> 1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Comm_size
> 1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Comm_rank
> 1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Init
> 1>E:\Visual Studio 2008\Projects\myprog\Debug\myprog.exe : fatal error
> LNK1120: 4 unresolved externals
> I've seen many posts with similar problems but unfortunately I haven't been
> able to solve the issue on my own. It looks like it's not seeing where my
> compiled mpi libs are but I have specified the MPICH2 libraries as
> "Additional dependencies" for the linker (set the path of MPICH2 libraries
> in "Additional library directories" and added mpi.lib as "Additional
> dependencies"). I have tried compiling with both VC++ and IntelC++, both of
> which have the directories for the include files and library files set under
> tools->options as well.
> Not sure what else to try. Any help is greatly appreciated.
> Thanks,
> Ryan
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110509/055169b8/attachment.htm>
