[mpich-discuss] mpiexec Hangs, cannot run examples
    Michael Morrison
    mwmorrison93 at gmail.com
    Sat May  7 01:12:19 CDT 2011
Hey all, I'm new to MPI so if anything doesn't make sense let me know and
I'll do my best to clarify. I'm attempting to set up MPI on an Amazon EC2
machine. I've gone through and followed the instructions in the instruction
manual but whenever I try to run one of the built in examples
(examples/cpi), the call simply hangs. Below is some information about my
system, my MPI set up and the output returned from mpiexec. Right now i'm
not even trying to run anything on a cluster, I simply want to run an MPI
application on one machine. Let me know what other information I can furnish
to help troubleshoot this problem. Thanks in advance for any help. Mike
1) First I ran mpd& to start the process manager
2) mpiexec -info yields the following information
HYDRA build details:
    Version:                                 1.4rc2
    Release Date:                            Thu Apr  7 11:17:20 CDT 2011
    CC:                              gcc
    CXX:                             c++
    F77:                             gfortran
    F90:                             f95
    Configure options:                       '--enable-timing=log_detailed'
'--with-logging=rlog' '--enable-timer-type=linux86_cycle'
'--enable-totalview' '--with-pm=hydra:mpd:gforker'
'--with-python=/root/Python-2.7.1/python' '--prefix=/root/mpi'
'--disable-option-checking' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt
-lpthread ' 'CPPFLAGS= -I/usr/local/mpich2-1.4rc2/src/mpl/include
-I/usr/local/mpich2-1.4rc2/src/openpa/src
-I/usr/local/mpich2-1.4rc2/src/mpid/ch3/include
-I/usr/local/mpich2-1.4rc2/src/mpid/common/datatype
-I/usr/local/mpich2-1.4rc2/src/mpid/common/locks
-I/usr/local/mpich2-1.4rc2/src/mpid/ch3/channels/nemesis/include
-I/usr/local/mpich2-1.4rc2/src/mpid/ch3/channels/nemesis/nemesis/include
-I/usr/local/mpich2-1.4rc2/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
-I/usr/local/mpich2-1.4rc2/src/util/wrappers
-I/usr/local/mpich2-1.4rc2/src/util/wrappers'
    Process Manager:                         pmi
    Launchers available:                     ssh rsh fork slurm ll lsf sge
none persist
    Binding libraries available:             hwloc plpa
    Resource management kernels available:   none slurm ll lsf sge pbs
    Checkpointing libraries available:
    Demux engines available:                 poll select
3) Next I run mpiexec -verbose -profile -n 1
/usr/local/mpich2-1.4rc2/examples/cpi the follow is output and then the
program just hangs
host: localhost
mpiexec options:
  Base path: /root/mpi/bin/
  Launcher: (null)
  Debug level: 1
  Enable X: -1
  Global environment:
    HOSTNAME=domU-12-31-39-0E-D4-53
    TERM=xterm
    SHELL=/bin/bash
    HISTSIZE=1000
    SSH_CLIENT=76.91.23.64 65438 22
    SSH_TTY=/dev/pts/0
    USER=root
    LD_LIBRARY_PATH=/root/mpi/lib:/root/mpi/lib/trace_rlog
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:
    EC2_HOME=/home/ec2
    MAIL=/var/spool/mail/root
PATH=/root/Python-2.7.1:/root/mpi/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/home/ec2/bin:/home/ec2/bin:/home/ec2/bin:/root/bin
    INPUTRC=/etc/inputrc
    PWD=/usr/local/mpich2-1.4rc2/examples
    JAVA_HOME=/usr/java/default
    LANG=en_US.UTF-8
    SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
    SHLVL=1
    HOME=/root
    LOGNAME=root
    CVS_RSH=ssh
    SSH_CONNECTION=76.91.23.64 65438 10.192.215.161 22
    PKG_CONFIG_PATH=/usr/lib/pkgconfig:/usr/local/lib/pkgconfig
    LESSOPEN=|/usr/bin/lesspipe.sh %s
    G_BROKEN_FILENAMES=1
    _=/root/mpi/bin/mpiexec
    OLDPWD=/root
  Hydra internal environment:
    GFORTRAN_UNBUFFERED_PRECONNECTED=y
    Proxy information:
      [1] proxy: localhost (1 cores)
      Exec list: /usr/local/mpich2-1.4rc2/examples/cpi (1 processes);
[mpiexec at domU-12-31-39-0E-D4-53] Timeout set to -1 (-1 means infinite)
[mpiexec at domU-12-31-39-0E-D4-53] Got a control port string of
domU-12-31-39-0E-D4-53:44113
Proxy launch args: /root/mpi/bin/hydra_pmi_proxy --control-port
domU-12-31-39-0E-D4-53:44113 --debug --demux poll --pgid 0 --proxy-id
[mpiexec at domU-12-31-39-0E-D4-53] PMI FD: (null); PMI PORT: (null); PMI
ID/RANK: -1
Arguments being passed to proxy 0:
--version 1.4rc2 --interface-env-name MPICH_INTERFACE_HOSTNAME --hostname
localhost --global-core-map 0,1,0 --filler-process-map 0,1,0
--global-process-count 1 --auto-cleanup 1 --pmi-rank -1 --pmi-kvsname
kvs_1549_0 --pmi-process-mapping (vector,(0,1,1)) --ckpoint-num -1
--global-inherited-env 27 'HOSTNAME=domU-12-31-39-0E-D4-53' 'TERM=xterm'
'SHELL=/bin/bash' 'HISTSIZE=1000' 'SSH_CLIENT=76.91.23.64 65438 22'
'SSH_TTY=/dev/pts/0' 'USER=root'
'LD_LIBRARY_PATH=/root/mpi/lib:/root/mpi/lib/trace_rlog'
'LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:'
'EC2_HOME=/home/ec2' 'MAIL=/var/spool/mail/root'
'PATH=/root/Python-2.7.1:/root/mpi/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/home/ec2/bin:/home/ec2/bin:/home/ec2/bin:/root/bin'
'INPUTRC=/etc/inputrc' 'PWD=/usr/local/mpich2-1.4rc2/examples'
'JAVA_HOME=/usr/java/default' 'LANG=en_US.UTF-8'
'SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass' 'SHLVL=1' 'HOME=/root'
'LOGNAME=root' 'CVS_RSH=ssh' 'SSH_CONNECTION=76.91.23.64 65438
10.192.215.161 22'
'PKG_CONFIG_PATH=/usr/lib/pkgconfig:/usr/local/lib/pkgconfig'
'LESSOPEN=|/usr/bin/lesspipe.sh %s' 'G_BROKEN_FILENAMES=1'
'_=/root/mpi/bin/mpiexec' 'OLDPWD=/root' --global-user-env 0
--global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y'
--proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1
--exec-local-env 0 --exec-wdir /usr/local/mpich2-1.4rc2/examples --exec-args
1 /usr/local/mpich2-1.4rc2/examples/cpi
[mpiexec at domU-12-31-39-0E-D4-53] Launch arguments:
/root/mpi/bin/hydra_pmi_proxy --control-port domU-12-31-39-0E-D4-53:44113
--debug --demux poll --pgid 0 --proxy-id 0
4) Here's some system info
Linux version 2.6.21.7-2.fc8xen (mockbuild at xenbuilder1.fedora.redhat.com)
(gcc version 4.1.2 20070925 (Red Hat 4.1.2-33)) #1 SMP Fri Feb 15 12:39:36
EST 2008
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110506/88a4962c/attachment.htm>
