[mpich-discuss] lnk 2019 error, hellow world on windows 7 (64bit), VS2008
    Biddiscombe, John A.
    biddisco at cscs.ch
    Fri May  6 04:18:41 CDT 2011
Last time I installed on windows (7) the service was not started/installed during setup and I had to manually do it.
I expect that's what's in the instructions referred to below.
JB
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: 05 May 2011 17:03
To: Ryan Price
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] lnk 2019 error, hellow world on windows 7 (64bit), VS2008
 There seems to be some problem with the MPICH2 installation. Uninstall MPICH2 and try the steps mentioned in the Section 9.4 (NOT 9.1) of the MPICH2 installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) to install MPICH2.
(PS: Usually the VS installations have support for building 64-bit applications. I would recommend building 64-bit apps with VS.)
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, May 3, 2011 12:28:51 PM
Thanks for your reply Jayesh.
I had the 64bit version of MPICH2 installed but do not have the 64bit components enabled in VS. So I decided to try uninstalling the 64bit version of MPICH2 and installed the 32bit version.
I tried running my helloworld program again and am no longer getting the linker error I was previously :) Unfortunately I know get another error :(
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host= my.host.name , port=8678) failed, exhaused all end points
Unable to connect to ' my.host.name:8678 ',
sock error: Error = -1
Maybe I didn't configure something correctly during setup. I would have thought this was due to the firewall but I did make sure that mpiexec and smpd are not blocked by windows firewall. Maybe I just need to bite the bullet and reinstall VS with 64bit components enabled and reinstall the 64bit version of MPICH2.
On Mon, May 2, 2011 at 8:19 AM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
# Make sure that you installed the 64-bit version of MPICH2.
# Make sure that you select the "solution platform" in VS to be "x64" (Usually the default one is "Win32" . There should be a drop-down box on the top of the VS interface that allows you to select the "solution platform" - You might have to select "Configuration Manager" and create a new "Active Solution platform". You might find more help in the VS help docs.)
# Make sure that the paths specified to MPICH2 libs are correct.
-Jayesh
Sent: Sunday, May 1, 2011 6:08:14 PM
Subject: [mpich-discuss] lnk 2019 error, hellow world on windows 7 (64bit), VS2008
I'm just trying to get a mpi hello world program up and running and can't seem to get it to build properly. I'm on windows7 using VS2008.
I get this error:
1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Finalize referenced in function _main
1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Comm_size referenced in function _main
1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Comm_rank referenced in function _main
1>myprog.obj : error LNK2019: unresolved external symbol _MPI_Init referenced in function _main
1>E:\Visual Studio 2008\Projects\myprog\Debug\myprog.exe : fatal error LNK1120: 4 unresolved externals
I've seen many posts with similar problems but unfortunately I haven't been able to solve the issue on my own. It looks like it's not seeing where my compiled mpi libs are but I have specified the MPICH2 libraries as "Additional dependencies" for the linker (set the path of MPICH2 libraries in "Additional library directories" and added mpi.lib as "Additional dependencies"). I have tried compiling with both VC++ and IntelC++, both of which have the directories for the include files and library files set under tools->options as well.
Not sure what else to try. Any help is greatly appreciated.
Ryan
mpich-discuss mailing list
