[mpich-discuss] mpich2-1.3.2p1 compile error
    Wei Huang
    huangwei at ucar.edu
    Wed May  4 16:25:56 CDT 2011
This option worked for me.
I'll try a later version with hydra-bind.
Wei Huang
VETS/CISL
National Center for Atmospheric Research
P.O. Box 3000 (1850 Table Mesa Dr.)
Boulder, CO 80307-3000 USA
(303) 497-8924
On May 4, 2011, at 11:25 AM, Dave Goodell wrote:
> The failure is coming from hwloc, which is technically an optional component.  Try configuring with the following argument: "--without-hydra-bindlib" or possibly "--with-hydra-bindlib=plpa".  Note that you will not be able to specify process binding via mpiexec.
> -Dave
> On May 4, 2011, at 9:40 AM CDT, Wei Huang wrote:
>> Hi, there,
>> I tried to compile mpich2-1.3.2p1, and configure with:
>> setenv CC pgcc
>> setenv FC pgf90
>> ./configure \
>>        --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
>> When I compile,  I go the error message below.
>> How do I solve this issue?
>> Thanks,
>> Wei
>> VETS/CISL
>> (303) 497-8924
>> Making all in src
>> make[5]: Entering directory `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
>>  CC     topology.lo
>> pgcc-Warning-Unknown switch: -fvisibility=hidden
>> PGC-S-0170-Designated initializers are not supported (topology.c: 497)
>> PGC-S-0170-Designated initializers are not supported (topology.c: 509)
>> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with severe errors
>> make[5]: *** [topology.lo] Error 1
>> make[5]: Leaving directory `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
>> make[4]: *** [all-recursive] Error 1
>> make[4]: Leaving directory `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
>> make[3]: *** [all-recursive] Error 1
>> make[3]: Leaving directory `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
>> make[2]: *** [all-redirect] Error 1
>> make[2]: Leaving directory `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
>> make[1]: *** [all-redirect] Error 2
>> make[1]: Leaving directory `/neem2/huangwei/src/mpich2-1.3.2p1/src'
>> make: *** [all-redirect] Error 2
>> compiler info:
>> neem>pgcc -V
>> pgcc 6.2-5 64-bit target on x86-64 Linux
>> Copyright 1989-2000, The Portland Group, Inc.  All Rights Reserved.
>> Copyright 2000-2006, STMicroelectronics, Inc.  All Rights Reserved.
>> neem>pgf90 -V
>> pgf90 6.2-5 64-bit target on x86-64 Linux
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
