[mpich-discuss] Implementation of MPI blocking Send
Darius Buntinas
buntinas at mcs.anl.gov
Fri Mar 25 11:12:37 CDT 2011
MPICH2 has several interfaces to support derivative implementations. One interface is the ADI3 or "device" interface. You can find the device implementations in src/mpid/ . The base MPICH2 distribution contains two device implementations: CH3 and dcmfd. The dcmfd device is specifically for BlueGene, so you can ignore that. The MPID_ functions are implemented by the devices, so you can find them in src/mpid/ch3/src .
The CH3 device also provides an "channel" interface for derivative implementations. The base MPICH2 distribution has a sock channel and a nemesis channel. You can find these in src/mpid/ch3/channels/ . Currently nemesis is the default channel. Nemesis uses shared memory for intranode communication, and uses network modules for internode communication. You can find the network modules in src/mpid/ch3/channels/nemesis/nemesis/netmod . Information on the netmod API can be found here:
http://wiki.mcs.anl.gov/mpich2/index.php/Nemesis_Network_Module_API
I hope this helps!
-d
On Mar 25, 2011, at 9:51 AM, vaibhav dutt wrote:
> Thanks for the reply. Actually I am trying to understand the inter-node communication procedure in MPICH.
> Are there any documents/papers on it as I was not able to find one. Does MPICH use RDMA for inter node communication?
> On Thu, Mar 24, 2011 at 5:28 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> MPICH2 is a large, complicated code base. Numerous tools have been developed over the years for navigating large, complicated codes; try grep, cscope, or ctags.
> -Dave
> On Mar 24, 2011, at 5:21 PM CDT, vaibhav dutt wrote:
> > Hi all,
> > I was trying to find out the implementation of a simple blocking send in MPICH for my research and it is given in a
> > file send.c. In that file, a routine MPID_Send is being used to send the message. But I was not able to find the implementation of
> > MPID_Send. Is the code for MPID_Send routine given in one of C++ files?
> > Thanks
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
