[mpich-discuss] a question related to installation of MPICH2 with pgf90 and pgcc (PGI fortran and c compiler)
    Rui Mei
    meir02ster at gmail.com
    Wed Mar 23 21:55:19 CDT 2011
I first set FC=/opt/pgi/linux86-64/10.4/bin/pgf90 and
CC=/opt/pgi/linux86-64/10.4/bin/pgcc and then run the configure command in
default. Do I need to add FC and CC as some option with configure command? I
thought defining them before executing configure should be fine.
Rui
On Wed, Mar 23, 2011 at 10:50 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> [please keep mpich-discuss cc'ed. Emails sent to individual developers are
> very likely to be dropped.]
> Your configure output does not indicate that you set CC or FC to anything.
> How exactly did you run configure?
> On 03/23/2011 09:46 PM, Rui Mei wrote:
>> Dear Pavan,
>> Thank you for your quick reply. It means a lot and some hope for me, I
>> have to say. I have been struggling with this research model for quite a
>> while:( Here is the configure output.
>> Sincerely,
>> Rui
>> On Wed, Mar 23, 2011 at 10:42 PM, Pavan Balaji <balaji at mcs.anl.gov
>>  <mailto:balaji at mcs.anl.gov>> wrote:
>>    Setting the CC variable to pgcc is the correct way to do this. Can
>>    you send us the configure output as described in the README?
>>      -- Pavan
>>    On 03/23/2011 09:39 PM, Rui Mei wrote:
>>        Dear all,
>>        I was trying to install MPICH2 with pgf90 and pgcc. So I set
>>        FC=pgf90
>>        and CC=pgcc before I configure. After sucessful installation of
>>        MPICH2,
>>        if I execute mpif90 -show, I will get
>>        "pgf90 -I/usr/local/mpi2/include -I/usr/local/mpi2/include
>>        -L/usr/local/mpi2/lib -L/usr/local/mpi2/lib -lmpichf90 -lmpichf90
>>        -lmpich -lopa -lpthread -lrt"
>>        and if I execute mpicc -show
>>        "gcc -I/usr/local/mpi2/include -L/usr/local/mpi2/lib
>>        -L/usr/local/mpi2/lib -lmpich -lopa -lpthread -lrt"
>>        So it shows that it still uses gcc not pgcc?
>>        The reason I am asking this is that when I run our resarch model
>>        with
>>        MPICH2, the default script will set FC=mpif90, CC=mpicc, to run the
>>        model, but the model would fail at the build process because it
>>        complains that mpicc can not recognize some option that pgcc do
>>        recognize, because if I set CC=pgcc, our research model can build
>>        and run without any problem. So I am wondering if my installation
>> of
>>        MPICH2 is using pgcc rather than gcc, the model may also be able to
>>        build and run with the default script setting CC=mpicc. So my
>>        question
>>        is how to do it? The reason I need to solve it is that when I
>>        run the
>>        model for some special configuration, it would fail even when I set
>>        CC=pgcc. Therefore, I must solve it with CC=mpicc, I guess.
>>        Thank you very much in advance for any advice.
>>        Best regards,
>>        Rui
>>        _______________________________________________
>>        mpich-discuss mailing list
>>        mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>>        https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>    Pavan Balaji
>>    http://www.mcs.anl.gov/~balaji
> Pavan Balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110323/0f53eb3d/attachment.htm>
