[mpich-discuss] 回复: MPICH mpiexec can't run if you install matlab
Jayesh Krishna jayesh at mcs.anl.gov
Mon Mar 21 10:31:03 CDT 2011
 Did you have any issues while installing MPICH2 ? The SMPD passphrase is specified during the installation step (a default SMPD passphrase, "behappy", is also provided during install). So if your installation was successful it is unlikely that you get prompted for "passphrase for SMPD" .
 I would recommend the following,
1) Uninstall your existing version of MPICH2.
2) Open an administrator command prompt by Right-clicking on the command prompt icon and selecting "Run as administrator" (Note that opening a command prompt from admin account DOES NOT give you an admin command prompt).
3) From within the administrator command prompt install MPICH2 using the msiexec utility (Type "msiexec /i mpich2-1.3.3rc1-win-x86-64.msi" from the admin command prompt).
4) The command above should bring up the installer GUI that will guide you through the installation process.
 After installing MPICH2 using the steps above try the "-localroot" option.
-Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, March 17, 2011 9:48:19 PM
Subject: 回复: [mpich-discuss] MPICH mpiexec can't run if you install matlab
Hi,Jayesh
Thank you very much for your reply. I do as what you said, but it still can't work and ask me to specify an authetication passphrase for smpd each time, I set an pwd but it still show nothing, after Ctrl+C to quit, it returns :
D:\MyProjects>mpiexec -localroot -n 3 cmpi.exe
Please specify an authentication passphrase for smpd:
Please specify an authentication passphrase for smpd: Please specify an authenti
cation passphrase for smpd: Please specify an authentication passphrase for smpd
mpiexec aborting job...
The thread is active but cannot be suspended
SuspendThread failed[0 times] with error 5 for process 0:4C62F82D-FB37-412a-B0A8
-6DC2380826C8:'cmpi.exe'
The thread to be suspended is no longer active, exit_code = 123
unable terminate process safely. exit_code = 123
unable to read the cmd header on the pmi context, Error = -1
Error posting readv, 远程主机强迫关闭了一个现有的连接。(10054)
job aborted:
rank: node: exit code[: error message]
0: Kay-PC: 123: mpiexec aborting job
1: Kay-PC: 123
2: Kay-PC: 123
D:\MyProjects>
can you help me to slove the problem ?
Thank you :)
Kong Tao
School of Maths,Shandong Univ.
发件人: Jayesh Krishna <jayesh at mcs.anl.gov>
收件人: mpich-discuss at mcs.anl.gov
抄 送: hawk_kongtao at yahoo.com.cn
发送日期: 2011/3/18 (周五) 4:26:32 上午
主 题: Re: [mpich-discuss] MPICH mpiexec can't run if you install matlab
Try the "-localroot" option with mpiexec (mpiexec -localroot -n 2 mygui_mpipgm.exe).
Jayesh
To: "MPI" < mpich-discuss at mcs.anl.gov >
Sent: Thursday, March 17, 2011 12:57:30 PM
Subject: [mpich-discuss] MPICH mpiexec can't run if you install matlab
Hi, everyone.
I can't not run the mpi program, my system is win7 intalled with matlab. and my mpich version is 1.3.3 rc1, My Gcc version is 4.5.2
I also have set the path of my system, make sure that the path of mpich2\bin before matalb\bin\win32
but I still can't run,neither the gui nor the cmd line. it returns nothing if you run in the command line.
I don't know why, and I am waiting for your reply, thank you ~
孔涛 山东大学数学学院
Mobile: 13688635846 Phone: 0531-88369020 QQ:584219201
mpich-discuss mailing list
