[mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
    孔涛
    tkong at mail.sdu.edu.cn
    Thu Mar 17 13:12:55 CDT 2011
hi, I am sorry to trouble you ,but could you send me a copy of mpich2-1.2.1p1.exe, I want to use this version, because the new version has some problem for me
thank you
Kay
------------------ Original ------------------
Date:  Fri, Mar 4, 2011 11:40 AM
To:  "Jayesh Krishna"<jayesh at mcs.anl.gov>;
Cc:  "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
Subject:  Re: [mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
 Hi,�Is there anyway to know that I am running with nemesis channel instead of sock channel?
I am launching my job via config file which is something look like this as below.
channel
 nemesis
exe \\FDS2-PC\Project\Paradigm\V20\fds5_mpi_win_64.exe Paradigmv4-20.fds
dir \\FDS2-PC\Project\Paradigm\V20\
hosts�
FDS2-PC 6
WIN7-PC 6
 Thanks.
Koh
On Wed, Mar 2, 2011 at 12:06 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
 �With MPICH2 1.2.1p1 you should be able to use the Nemesis channel using the "-channel" option of mpiexec (mpiexec -n 2 -channel nemesis mympipgm.exe).
 Jayesh
 ----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
 Cc: mpich-discuss at mcs.anl.gov
 Sent: Tuesday, March 1, 2011 6:39:25 AM
 Thanks for the reply. Are there any old version which use Nemesis channel?
 Thanks.
 Koh
 On Mon, Feb 28, 2011 at 9:34 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
 Try the latest stable release of MPICH2 ( http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads ).
 It looks like you are explicitly using the sock channel (with "-channel sock" option of mpiexec) for running your MPI job. Is there any reason why you want to use the sock channel instead of the default nemesis channel (If you don't use the "-channel" option mpiexec should pick the nemesis channel) ? Sock channel is old and we recommend all users to use the Nemesis channel instead.
 Jayesh
 Sent: Sunday, February 27, 2011 8:47:39 PM
 Subject: [mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
 Hi, I am running 2 PC both with Window 7 home premium edition for parallel calculation by using MPICH2 version mpich2-1.2.1p1, it run for 3D FDS calculation which runs for a while and then fails with a number of MPI error messages as below.
 Fatal error in MPI_Allreduce: Other MPI error, error stack:
 MPI_Allreduce(773)........................: MPI_Allreduce(sbuf=000000003FC70738,
 rbuf=000000003FC706F8, count=10, MPI_LOGICAL, MPI_LXOR, MPI_COMM_WORLD) failed
 MPIR_Bcast(1031)..........................:
 MPIR_Bcast_binomial(157)..................:
 MPIC_Recv(83).............................:
 MPIC_Wait(513)............................:
 MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an
 event returned by MPIDU_Sock_Wait()
 MPIDI_CH3I_Progress_handle_sock_event(420):
 MPIDU_Sock_wait(2606).....................: The semaphore timeout period has exp
 ired. (errno 121)
 MPI_Allreduce(773)........................: MPI_Allreduce(sbuf=000000003FC707B8,
 rbuf=000000003FC70778, count=10, MPI_LOGICAL, MPI_LXOR, MPI_COMM_WORLD) failed
 MPIR_Allreduce(289).......................:
 MPIC_Sendrecv(164)........................:
 ired. (errno 121)
 I tried to ping test on each PC and its failed. It seem like I got no response from the network adapter.
 I disabled the network adapter and enabled it then everything seem to be normal again.
 Both PC are connected by using a crossover cable.
 Thanks.
 Koh
 mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110318/282e2bc7/attachment.htm>
