[mpich-discuss] Process termination with Hydra
    Pavan Balaji
    balaji at mcs.anl.gov
    Fri Mar 11 01:30:16 CST 2011
Hi Rohit,
I think I know what's happening here -- earlier versions of Hydra used
to cleanup all processes from all process groups, but we changed that to
kill only one process group at a time (each spawn creates a new process
group). The reason for this is to allow errors in a parent or child to
not affect the other when disconnected. However, when you don't use
connect/accept, this is not correct.
I have a patch for this and will commit it in after some more testing.
  -- Pavan
On 03/10/2011 07:17 PM, Jain, Rohit wrote:
> This is continuation to my earlier message with specific example.
> When application crashes with mpd, it exits with following message:
> rank 0 in job 1 mach1_42736 caused collective abort of all ranks
> exit status of rank 0: killed by signal 9
> With Hydra, application crashes, it hangs.
> When you do Ctrl-C, it show following message, but there are still
> application process around (not cleaned up):
> Ctrl-C caught... cleaning up processes
> Is it known issue with Hydra?
> Regards,
> Rohit
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
