[mpich-discuss] No requirement for smpd.exe in MPICH2-1.3.3
    Robert Hunter
    Robert.M.Hunter at usace.army.mil
    Wed Mar  9 16:33:11 CST 2011
Jayesh,
Thanks for the information regarding smpd.exe.
I still have a question as to how I would run without installing smpd. I've tried the following:
I copied smpd.exe, mpiexec.exe to a dir named C:\mpich2\bin, I then added this dir my to my PATH. I also copied mpich2mpi.dll, mpich2nemesis.dll, and cpi.exe to C:\mpich2 . I then unistalled mpich2-1.3.3rc1 and rebooted. Next I tried the following in the c:\mpich2 dir   ".\bin\mpiexec.exe -localonly 2 cpi.exe"  The following output is what  I get:
C:\mpich2>.\bin\mpiexec.exe -localonly 2 .\cpi.exe
Unknown option: -d
Error while connecting to host, No connection could be made because the
target machine actively refused it. (10061)
Connect on sock (host=bhunter-lt.erdc.hpc.mil, port=8676) failed,
exhaused all end points
Unable to connect to 'bhunter-lt.erdc.hpc.mil:8676',
sock error: Error = -1
ReadFile() failed, error 109
unable to start the local smpd manager.
C:\mpich2>
Note: I don't have admin privileges on the machine.
Thanks for any help.
Bobby
On Mar 3, 2011, at 11:18 AM, Jayesh Krishna wrote:
> Hi,
>  MPICH2 1.3.3 did not remove the requirement for smpd.exe .
>  When using the "-localonly' option with mpiexec you do not need to have SMPD installed on the system. MPICH2 1.3.3 removed firewall issues when starting MPI jobs with the "-localonly" option.
>  So you still need SMPD to be available, but you don't need to install SMPD or worry about firewall issues when running all MPI processes on the local node.
> Regards,
> Jayesh
> From: "Robert Hunter" <Robert.M.Hunter at usace.army.mil>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 3, 2011 7:33:21 AM
> Subject: [mpich-discuss] No requirement for smpd.exe in MPICH2-1.3.3
> I came across a note @ boinc.berkley.edu that stated mpich2-1.3.3 should remove the requirement for smpd.exe, as well as no firewall issues on Windows. I've downloaded and tried this method with the mpich-1.3.3r1-win-ia32 install and using the following command line "mpiexec -localonly -n 2 -channel nemesis:none cpi.exe" but it simply returns the following error "Uknown option -d". Will these functionality be included in the MPICH2-1.3.3 release?
> Thanks,
> Bobby
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110309/86ab6b80/attachment.htm>
