[mpich-discuss] Jumpshot and mpich2-1.3.3rc1
Nicolas Rosner nrosner at gmail.com
Mon Mar 7 20:08:24 CST 2011
> in the past [...] setting JRE env would make Jumpshot run fine
Did you try setting JRE_HOME instead of JRE?
N.
# Set JAVA runtime through env variables:
# JAVA_HOME, JRE_HOME, JVM, or the value determined by configure.
if [ -n "${JAVA_HOME}" -a -x "${JAVA_HOME}/bin/java" ] ; then
    JVM="${JAVA_HOME}/bin/java"
elif [ -n "${JRE_HOME}" -a -x "${JRE_HOME}/bin/java" ] ; then
    JVM="${JRE_HOME}/bin/java"
else
    JVM=${JVM:-"/usr/bin/java"}
fi
JVMOPTS=""
# Assume user's environmental JVMFLAGS is better than what configure found.
JVMFLAGS=${JVMFLAGS:-${JVMOPTS}}
