[mpich-discuss] Jumpshot and mpich2-1.3.3rc1
Jain, Rohit Rohit_Jain at mentor.com
Mon Mar 7 19:12:21 CST 2011
I am moving closer to migrating from mpich2-1.0.6 to mpich2-1.3.3rc1.
This problem is related to using Jumpshot.
I built mpich2 with --enable-mpe. I ran application and generated
Unknown.clog2 file.
When I try to run Jumpshot, I get this error:
jumpshot Unknown.slog2
GUI_LIBDIR is set. GUI_LIBDIR =
/mpich2_debug/install-mpe/mpich2-1.3.3rc1/linux/lib
Warning: -Xms32m not understood. Ignoring.
Warning: -Xmx512m not understood. Ignoring.
Warning: -jar not understood. Ignoring.
Exception in thread "main" java.lang.NoClassDefFoundError:
.mpich2_debug.install-mpe.mpich2-1.3.3rc1.linux.lib.jumpshot.jar
   at gnu.gcj.runtime.FirstThread.run() (/usr/lib64/libgcj.so.5.0.0)
   at _Jv_ThreadRun(java.lang.Thread) (/usr/lib64/libgcj.so.5.0.0)
   at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
   at __gcj_personality_v0 (/function1/java.version=1.4.2)
   at __libc_start_main (/lib64/tls/libc-2.3.4.so)
   at _Jv_RegisterClasses (/function1/java.version=1.4.2)
>From the error message, it seems that issues has to do with either java
runtime or build environment.
In past, I had built mpich2-1.0.6 with -with-java= option, and setting
JRE env would make Jumpshot run fine. I don't see -with-java option with
mpich2-1.3.3rc1.
Rohit
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110307/fb21771f/attachment.htm>
