[mpich-discuss] A question when configure
Anthony Chan chan at mcs.anl.gov
Mon Mar 7 11:21:06 CST 2011
The reason that configure can't find your ifort/icc could be that
the intel compilers are installed in non-standard location.  Can you
configure as follows from a fresh new tarball ?
./configure CC=<path-to-intel-compilers>/bin/icc
            CXX=<path-to_intel-compilers>/bin/icpc
            F77=<path-to-intel-compilers>/bin/ifort
            FC=<path-to-intel-compilers>/bin/ifort
            --prefix=<mpich2-install-dir> 2>&1 | tee c.txt
make 2>&1 | tee m.txt
make install 2>&1 | tee mi.txt
make installcheck 2>&1 | tee mic.txt
If any of these steps fails, send us the .txt files.
A.Chan
----- Original Message -----
> Thanks, this is my c.txt in the attached file.
> The case seems that: If i install gnu_f77 or f95 ,it works, But i
> wanna use ifort and icc, and i also have them exported as FC CC in my
> .bashrc.
> At 2011-03-06 12:20:56,"Anthony Chan" <chan at mcs.anl.gov> wrote:
> >send us your configure output, c.txt, as stated in the
> >mpich2's README file and the top level config.log.
> >> Thank you, but I got all youguys said done, it just doesn't work.
> >> In fact, I build other sourcecode with ifort ok, but this one just
> >> says cannot find fortran compliers, I don't know y?
> >> At 2011-03-05 01:31:25,"Gus Correa" <gus at ldeo.columbia.edu> wrote:
> >> >Anthony Chan wrote:
> >> >> environment variable F90 is replaced by FC, so you don't need to
> >> >> set
> >> >> F90. Is ifort found in your PATH ? If not, you need to set F77
> >> >> and
> >> >> FC
> >> >> to full path of ifort. If that still does not work, send us your
> >> >> configure
> >> >> output, c.txt, as stated in the README as well as the top level
> >> >> config.log
> >> >> (which is generated automatically when configure is executed) ?
> >> >> A.Chan
> >> >>> Dear experts:
> >> >>> I Download the mpich2-1.3.2 On my ubuntu, when i configure, it
> >> >>> says
> >> >>> cannot find my fortran complier, I have intel -fortran
> >> >>> installed,
> >> >>> and
> >> >>> also set the environment in my .bashrc (export FC=ifort, export
> >> >>> F90=ifort, export F77=ifort), But it still cannot continue,
> >> >>> thank
> >> >>> you
> >> >>> for the reply!
> >> >>> Best Regards
> >> >Hi ZuiBeiDeMei
> >> >If you do 'which ifort' what do you get?
> >> >You may not have set the ifort environment properly.
> >> >This is done sourcing a shell script on the Intel directories
> >> >(search
> >> >their bin directory) called ifortvars.sh or ifortvars.csh
> >> >(depending
> >> >on
> >> >the shell you use, it looks like it is bash, so use ".sh"):
> >> >source /path/to/intel/bin/ifortvars.sh (or similar).
> >> >Or look at the Intel documentation, for more detail.
> >> >You can source them inside your .bashrc.
> >> >The 'export FC=ifort', etc, only doesn't do the whole job.
> >> >I hope it helps,
> >> >Gus Correa
> >> >_______________________________________________
> >> >mpich-discuss mailing list
> >> >mpich-discuss at mcs.anl.gov
> >> >https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
