[mpich-discuss] A question when configure
    Anthony Chan
    chan at mcs.anl.gov
    Sat Mar  5 22:20:56 CST 2011
send us your configure output, c.txt, as stated in the
mpich2's README file and the top level config.log.
----- Original Message -----
> Thank you, but I got all youguys said done, it just doesn't work.
> In fact, I build other sourcecode with ifort ok, but this one just
> says cannot find fortran compliers, I don't know y?
> At 2011-03-05 01:31:25,"Gus Correa" <gus at ldeo.columbia.edu> wrote:
> >Anthony Chan wrote:
> >> environment variable F90 is replaced by FC, so you don't need to
> >> set
> >> F90. Is ifort found in your PATH ? If not, you need to set F77 and
> >> FC
> >> to full path of ifort. If that still does not work, send us your
> >> configure
> >> output, c.txt, as stated in the README as well as the top level
> >> config.log
> >> (which is generated automatically when configure is executed) ?
> >> A.Chan
> >>> Dear experts:
> >>> I Download the mpich2-1.3.2 On my ubuntu, when i configure, it
> >>> says
> >>> cannot find my fortran complier, I have intel -fortran installed,
> >>> and
> >>> also set the environment in my .bashrc (export FC=ifort, export
> >>> F90=ifort, export F77=ifort), But it still cannot continue, thank
> >>> you
> >>> for the reply!
> >>> Best Regards
> >Hi ZuiBeiDeMei
> >If you do 'which ifort' what do you get?
> >You may not have set the ifort environment properly.
> >This is done sourcing a shell script on the Intel directories (search
> >their bin directory) called ifortvars.sh or ifortvars.csh (depending
> >on
> >the shell you use, it looks like it is bash, so use ".sh"):
> >source /path/to/intel/bin/ifortvars.sh (or similar).
> >Or look at the Intel documentation, for more detail.
> >You can source them inside your .bashrc.
> >The 'export FC=ifort', etc, only doesn't do the whole job.
> >I hope it helps,
> >Gus Correa
> >_______________________________________________
> >mpich-discuss mailing list
> >mpich-discuss at mcs.anl.gov
> >https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
