[mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Mar  4 10:29:15 CST 2011
 Is there a reason why you want to use a config file (We do not regularly test the various config file options)? You could just run your job as,
    mpiexec -n 12 -channel nemesis -machinefile mf.txt -map J:\\FDS2-PC\Project\Paradigm -wdir J:\V20 fds5_mpi_win_64.exe Paradigmv4-20.fds
 where machine file, mf.txt, contains
    # Machine file for FDS5
    # Hosts and max procs to run on each host listed below
    FDS2-PC:6
    WIN7-PC:6
    # End of the machine file
 Let us know if it works for you.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Thursday, March 3, 2011 9:40:39 PM
Subject: Re: [mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
Is there anyway to know that I am running with nemesis channel instead of sock channel?
I am launching my job via config file which is something look like this as below.
channel
nemesis
exe \\FDS2-PC\Project\Paradigm\V20\fds5_mpi_win_64.exe Paradigmv4-20.fds
dir \\FDS2-PC\Project\Paradigm\V20\
hosts
FDS2-PC 6
WIN7-PC 6
Thanks.
Koh
On Wed, Mar 2, 2011 at 12:06 AM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
With MPICH2 1.2.1p1 you should be able to use the Nemesis channel using the "-channel" option of mpiexec (mpiexec -n 2 -channel nemesis mympipgm.exe).
Jayesh
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
Sent: Tuesday, March 1, 2011 6:39:25 AM
Thanks for the reply. Are there any old version which use Nemesis channel?
Thanks.
Koh
On Mon, Feb 28, 2011 at 9:34 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Try the latest stable release of MPICH2 ( http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads ).
It looks like you are explicitly using the sock channel (with "-channel sock" option of mpiexec) for running your MPI job. Is there any reason why you want to use the sock channel instead of the default nemesis channel (If you don't use the "-channel" option mpiexec should pick the nemesis channel) ? Sock channel is old and we recommend all users to use the Nemesis channel instead.
Jayesh
Sent: Sunday, February 27, 2011 8:47:39 PM
Subject: [mpich-discuss] mpich2-1.2.1p1 runs for a while and failed
Hi, I am running 2 PC both with Window 7 home premium edition for parallel calculation by using MPICH2 version mpich2-1.2.1p1, it run for 3D FDS calculation which runs for a while and then fails with a number of MPI error messages as below.
Fatal error in MPI_Allreduce: Other MPI error, error stack:
MPI_Allreduce(773)........................: MPI_Allreduce(sbuf=000000003FC70738,
rbuf=000000003FC706F8, count=10, MPI_LOGICAL, MPI_LXOR, MPI_COMM_WORLD) failed
MPIR_Bcast(1031)..........................:
MPIR_Bcast_binomial(157)..................:
MPIC_Recv(83).............................:
MPIC_Wait(513)............................:
MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an
event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Sock_wait(2606).....................: The semaphore timeout period has exp
ired. (errno 121)
MPI_Allreduce(773)........................: MPI_Allreduce(sbuf=000000003FC707B8,
rbuf=000000003FC70778, count=10, MPI_LOGICAL, MPI_LXOR, MPI_COMM_WORLD) failed
MPIR_Allreduce(289).......................:
MPIC_Sendrecv(164)........................:
ired. (errno 121)
I tried to ping test on each PC and its failed. It seem like I got no response from the network adapter.
I disabled the network adapter and enabled it then everything seem to be normal again.
Both PC are connected by using a crossover cable.
Thanks.
Koh
mpich-discuss mailing list
