[mpich-discuss] MPI_Comm_spawn(), dynamic distribution and hydra
Roberto Fichera
kernel at tekno-soft.it
Wed Mar 2 05:55:05 CST 2011
Hi All,
I made a parallelization library on top of the MPICH2 library that basically
performs a dynamic job's distribution among all the assigned nodes. So
the library makes an heavy use of MPI_Comm_spawn() in a MPI_THREAD_MULTIPLE
configure MPICH2 library. This works pretty fine and we are able to easily differentiate
the spawned jobs algorithms once decomposing the data. Furthermore the library
permit the user to specify more than one node to assign to any given job. This end up
on "electing" the given slave node to become a master of a node subset (submastering)
to perform more fine grained parallel distribution as per user's algorithm. So
typical distribution scenery is like a tree where the nodes are submasters. Since we
discover that for certain algorithm we might need to dynamically decide the number
of nodes to dedicate for any given submastering parallel computation. So I started to
investigate if would be possible to make an interface with the cluster resource manager
and the library we use.
So my idea is that in certain condition before to call the MPI_Comm_spawn() for spawning
a job into a well defined hostname I would like to reserve, via the resource manager, the
number of node requested by the given submastering job. So my first thought was to make
an interface against PBS (it's our cluster manager/scheduler) using its libpbs and basically
implementing something like a qsub/mpiexec function call, but I come at the conclusion
that for implementing the dynamic bootstrap process, for the newly allocated
node, Hydra would be much more flexible in such sense, since it seems providing a more
abstracted interface for doing such integration.
So my question is: does anyone know a better way to do so? Might it create
problems or not I don't see in some way?
Any suggestion will be really appreciated.
Thanks in advance.
Roberto Fichera.
