[mpich-discuss] issues when writing a simple makefile to build MPI programs
    clara
    clarazhang at gmail.com
    Sat Jun 25 09:40:21 CDT 2011
Attached please find the output info when I ran configure with -m32 option.
Because I am building 64-bit libraries, the log files cannot be obtained
now.
- Clara
On Sat, Jun 25, 2011 at 10:28 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Can you send us the log files are described in the README? Please compress
> them as they can be huge.
>  -- Pavan
> On 06/25/2011 09:12 AM, clara wrote:
>> Thanks, but now I get the below error:
>> configure: error: Could not determine a way to link a Fortran test
>> program!
>> On Sat, Jun 25, 2011 at 9:59 AM, Pavan Balaji <balaji at mcs.anl.gov
>> <mailto:balaji at mcs.anl.gov>> wrote:
>>    It's "CFLAGS", not "CFLAG".
>>      -- Pavan
>>    On 06/25/2011 08:42 AM, clara wrote:
>>        I executed the following command:
>>        ./configure --prefix=/mnt/lux/git/pios/xc/**__mpich2-32
>>        --with-pm=gforker
>>        --disable-faster CFLAG=-m32 CXXFLAGS=-m32 FFLAGS=-m32 FCFLAGS=-m32
>>        and got the below errors:
>>        configure: error: ****  Incompatible Fortran and C Object File
>>        Types!  ****
>>        F77 Object File Type produced by "gfortran -m32 " is : : ELF
>>        32-bit LSB
>>        relocatable, Intel 80386, version 1 (SYSV), not stripped.
>>          C  Object File Type produced by "gcc    -O2" is : : ELF 64-bit
>> LSB
>>        relocatable, x86-64, version 1 (SYSV), not stripped.
>>        Is there any simple way setting -m32 in order to build 32-bit
>>        libraries
>>        on 64-bit system?
>>        - Clara
>>        On Fri, Jun 24, 2011 at 11:53 AM, Anthony Chan <chan at mcs.anl.gov
>>        <mailto:chan at mcs.anl.gov>
>>        <mailto:chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>>> wrote:
>>            You need to rebuild mpich2 for 32bit.  Set
>>            CFLAGS/CXXFLAGS/FFLAGS/FCFLAGS
>>            to -m32 (assume your system has the 32bit support).
>>            BTW, your install of 1.2.1p1 mpich2 is old, please upgrade
>>        if possible
>>            (the latest stable release is 1.4)
>>            A.Chan
>>            ----- Original Message -----
>>         > I think the default installed mpich2 in 64-bit ubuntu is in
>>        x86_64
>>         > mode.
>>         > When I try to compile/link an MPI program in 32-bit mode,
>>        there is an
>>         > error
>>         > below:
>>         > /usr/lib/libmpich.so: file not recognized: File format not
>>        recognized
>>         > How can I configure the compile/link flags? Do I need to rebuild
>>         > mpich2 to
>>         > get a 32-bit libraries? Or is there any 32-bit libraries
>>        coexisted
>>         > with
>>         > 64-bit libraries? Thanks.
>>         > Below is the output version information of the default installed
>>         > MPICH2:
>>         > MPICH2 Version: 1.2.1p1
>>         > MPICH2 Release date: Unknown, built on Tue Apr 27 15:06:31
>>        UTC 2010
>>         > MPICH2 Device: ch3:nemesis
>>         > MPICH2 configure: --build=x86_64-linux-gnu --prefix=/usr
>>         > --includedir=${prefix}/include --mandir=${prefix}/share/man
>>         > --infodir=${prefix}/share/info --sysconfdir=/etc
>>        --localstatedir=/var
>>         > --libexecdir=${prefix}/lib/__**mpich2 --disable-maintainer-mode
>>         > --disable-dependency-tracking --disable-silent-rules --srcdir=.
>>         > --enable-sharedlibs=gcc --prefix=/usr --enable-f90
>>         > --sysconfdir=/etc/mpich2
>>         > --includedir=/usr/include/__**mpich2
>> --docdir=/usr/share/doc/mpich2
>>         > MPICH2 CC: gcc -g -O2 -g -Wall -O2 -O2
>>         > MPICH2 CXX: c++ -g -O2 -g -Wall -O2 -O2
>>         > MPICH2 F77: gfortran -g -O2 -O2
>>         > MPICH2 F90: f95 -O2
>>         > - Clara
>>         > On Fri, Jun 24, 2011 at 12:08 AM, Pavan Balaji
>>        <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>
>>        <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>>
>>         > wrote:
>>         > > Clara,
>>         > > On 06/23/2011 10:53 PM, clara wrote:
>>         > >> If I only use shared memory communication among processes on
>> a
>>         > >> single
>>         > >> node, how can I configure the mpich2.1.4 (except
>>            --with-pm=gforker)
>>         > >> in
>>         > >> order to link libraries as little as possible?
>>         > > Shared memory communication support comes by default in
>>        MPICH2. You
>>         > > don't
>>         > > need to pass any special configure options; not even
>>         > > --with-pm=gforker.
>>         > > Unfortunately, all libraries are still required to be
>>        linked with
>>         > > even when
>>         > > only shared memory support is needed.
>>         > >  -- Pavan
>>         > > Pavan Balaji
>>         > > http://www.mcs.anl.gov/~balaji
>>         > ______________________________**___________________
>>         > mpich-discuss mailing list
>>         > mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.**gov<mpich-discuss at mcs.anl.gov>
>>        <mailto:mpich-discuss at mcs.anl.**__gov
>>        <mailto:mpich-discuss at mcs.anl.**gov <mpich-discuss at mcs.anl.gov>>>
>>         > https://lists.mcs.anl.gov/__**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/__mailman/listinfo/mpich-discuss>
>>        <https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
>>    Pavan Balaji
> Pavan Balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110625/50f05b0f/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110625/50f05b0f/attachment-0001.obj>
