[mpich-discuss] MPICH2 1.3.2 build using Intel Fortran, Gcc
john smith
js at cham.co.uk
Fri Jun 24 08:22:10 CDT 2011
hello,
Having a problem building MPICH2 1.3.2 on 32bit Fedora 3 Linux
configure: error: **** Incompatible Fortran and C Object File Types! ****
F77 Object File Type produced by "ifort -O2" is : : ELF 32-bit LSB relocatable, Intel 80386, version 1 (GNU/Linux), not stripped.
C Object File Type produced by "gcc -O2" is : : ELF 32-bit LSB relocatable, Intel 80386, version 1 (SYSV), not stripped.
Intel Fortran is 9.0.025, GCC is 4.5.1
Attached are the files you require,
John
CHAM Ltd, 40 High Street, Wimbledon, London SW19 5AU
Tel: +44-208-947-7651 Fax: +44-208-879-3497
Web: http://www.cham.co.uk
Email: js at cham.co.uk
Click: www.cham.co.uk/DOCS/cham_news_winter0809.pdf for the latest news from CHAM
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110624/892f3424/attachment-0001.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110624/892f3424/attachment-0001.txt>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110624/892f3424/attachment-0001.obj>
Type: application/msword
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110624/892f3424/attachment-0002.doc>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110624/892f3424/attachment-0003.doc>
