[mpich-discuss] Parallel I/O on Lustre: MPI Vs. POSIX
George Zagaris
george.zagaris at kitware.com
Mon Jun 20 15:52:12 CDT 2011
Dear All:
I am currently investigating what would be the best I/O strategy for large-scale
data targeting in particular the Lustre architecture.
Towards this end, I developed a small benchmark (also attached) where
each process
writes and reads 4,194,304 doubles (32MB per process) with MPI I/O on
a single shared file
and POSIX I/O on a separate files -- one file per process.
I run this code with 32 processes under a directory which has:
(a) stripe size equal to 32MB, i.e., data is stripe aligned, and
(b) stripe count (number of OSTs) set to 32
I would expect that given the above configuration there will be no
file-system contention
since the data is stripe aligned and the number of OSTs is equal to
the number of processes
that are performing the I/O. Hence, I would expect that the
performance of the MPI I/O would
be close to the POSIX performance. The raw performance numbers that I
obtained do not
corroborate this theory however:
MPI-WRITE-OPEN: 0.0422981
MPI-WRITE-CLOSE: 0.000592947
MPI-WRITE: 0.0437472
MPI-READ-OPEN: 0.00699806
MPI-READ-CLOSE: 1.30613
MPI-READ: 1.30675
POSIX-WRITE-OPEN: 0.017261
POSIX-WRITE-CLOSE: 0.00202298
POSIX-WRITE: 0.00158501
POSIX-READ-OPEN: 0.00238109
POSIX-READ-CLOSE: 0.000462055
POSIX-READ: 0.00268793
I was wondering if anyone has experience with using MPI I/O on lustre
and whether
using hints can improve the I/O performance. Any additional, thoughts, comments
or suggestions on this would also be very welcome.
I sincerely thank you for all your time & help.
Best Regards,
George
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110620/0c8ed0db/attachment.cxx>
