[mpich-discuss] MPICH2 Installation and Testing
Anthony Chan chan at mcs.anl.gov
Fri Jun 17 11:18:48 CDT 2011
The last 2 programs in "make testing" are meant to fail (the names
of the test programs are wrong_*), so your MPICH2-1.4 installation
is good to go.
A.Chan
----- Original Message -----
> Hi MPICH2 Supporter,
> I have downloaded, built and installed the latest stable version using
> Intel Compiler i.e., MPICH2-1.4. Default installation is fine but the
> last
> two programs are failed is given below. I have no idea of "Fatal error
> in
> MPI_Comm_call_errhandler". Can you tell me find the problem of the
> last two
> programs?
> Thanks,
> Ashok.
> Running installation linktest for C logging program...
> *** Link C program with the MPI tracing library
> Yes.
> *** Link C program with the MPI logging library
> Yes.
> *** Link C program with the MPI and manual logging libraries
> Yes.
> Running installation linktest for Fortran logging program...
> *** Link F77 program with the MPI and manual logging libraries
> Yes.
> Running installation linktest for C graphics program...
> *** Link C program with the MPI animation library
> Yes.
> *** Link C program with the X11 graphics library
> Yes.
> Running installation linktest for Fortran graphics program...
> *** Link F77 program with the X11 graphics library
> Yes.
> Running installation linktest for C collchk program...
> *** Link C program with the MPI collective/datatype checking library
> Yes.
> Running installation linktest for Fortran collchk program...
> *** Link F77 program with the MPI collective/datatype checking library
> Yes.
> make[1]: Leaving directory
> `/home/vignesh/Softwares/MPICH2/intel/mpich2-1.4/src/mpe2'
> make installcheck-postamble
> make[1]: Entering directory
> `/home/vignesh/Softwares/MPICH2/intel/mpich2-1.4'
> make[2]: Entering directory
> Running installation runtest for C logging program...
> *** Test C program with the MPI tracing library
> Yes.
> *** Test C program with the MPI logging library
> Yes.
> Convert cpi_log.clog2 to slog2 file .............. Yes.
> *** Test C program with the MPI and manual logging libraries
> Yes.
> Convert cpilog.clog2 to slog2 file .............. Yes.
> Running installation runtest for Fortran logging program...
> *** Test F77 program with the MPI and manual logging libraries
> Yes.
> Convert fpilog.clog2 to slog2 file .............. Yes.
> Running installation runtest for C graphics program...
> *** Test C program with the MPI animation library
> Yes.
> *** Test C program with the X11 graphics library
> Yes.
> Running installation runtest for Fortran graphics program...
> *** Test F77 program with the X11 graphics library
> Yes.
> Running installation runtest for C collchk program...
> *** Test C program with the MPI collective/datatype checking library
> No.
> The failed command is :
> /home/vignesh/mpich2/1.4/intel/bin/mpiexec -n 4 wrong_int_byte
> Starting MPI Collective and Datatype Checking!
> Backtrace of the callstack at rank 3:
> At [0]: wrong_int_byte(CollChk_err_han+0xcf)[0x80557ef]
> Fatal error in MPI_Comm_call_errhandler:
> Collective Checking: BCAST (Rank 3) --> Inconsistent datatype
> signatures
> detected between rank 3 and rank 0.
> Running installation runtest for Fortran collchk program...
> *** Test F77 program with the MPI collective/datatype checking library
> No.
> /home/vignesh/mpich2/1.4/intel/bin/mpiexec -n 4 wrong_reals
> Process 0 of 4 is alive
> Process 1 of 4 is alive
> Process 2 of 4 is alive
> Process 3 of 4 is alive
> At [0]: wrong_reals(CollChk_err_han+0xcf)[0x806282f]
> signatures
> make[2]: Leaving directory
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
