[mpich-discuss] download links are broken
Gao,Fei fgao at uchc.edu
Fri Jun 17 10:29:07 CDT 2011
Hi Pavan,
I did try to build from source. I saw the instructions and I also saw Visual Studio solution file.  I tried the following:
1.  I directly opened Visual Studio solution file and built it but I got huge set of errors.  Most complained about missing mpi.h. I guess I had to follow the instructions and generate missing include files. So I did next.
2. I tried to follow the instructions and failed at step (c) maint/updatefiles.  Here is the error that I got.
Generating parameter handling code... Can't use an undefined value as an ARRAY reference at ./maint/genparams line 88.
failed
===> ERROR:   unable to generate parameter handling code
You see building mpich2 is not my intention and I need to build something else that needs mpich2. I think I will wait for the binaries.
Fei
-----Original Message-----
Sent: Friday, June 17, 2011 10:56 AM
Cc: Gao,Fei; Beth Cerny Patino
Subject: Re: [mpich-discuss] download links are broken
Hi Fei,
On 06/17/2011 09:50 AM, Gao,Fei wrote:
> The download links for MPICH2 1.4 for Windows binaries (32bit and
> 64bit) on web page http://www.mcs.anl.gov/research/projects/mpich2/ are broken.
No, the MPICH2 windows binaries are not uploaded yet. Only the source tarball has been uploaded.
The binaries will be uploaded in a few days. Alternatively, you can build MPICH2 from source.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
