[mpich-discuss] Compile error with "undefined reference"
    tetsuro_kikuchi at jesc.or.jp
    Thu Jun 16 02:26:24 CDT 2011
Hello.
I'm trying to compile an executable of a program using MPICH2 (version:
1.3.2p1). However, it failed with messages "undefined reference to '...'".
The error part of the compile log ("bldit.cctm_errorlog110616.txt") is
attached below. Could anyone teach me what is wrong and how to solve this
problem?
My system uses Ubuntu Linux (version 11.04 (64-bit)) as OS and Intel
Fortran Composer XE 2011 for Linux as compiler. I also attach the configure
log of MPICH2 ("c.txt") and a set of the related C source codes to this
error ("initthread.c", "param_vals.c", "mpid_vc.c", "init.c" and
"tcp_init.c") below.
Tetsuro
(See attached file: bldit.cctm_errorlog110616.txt)(See attached file:
c.txt)(See attached file: initthread.c(mpich2-1.3.2p1&src&mpi&init).txt)
(See attached file: param_vals.c(mpich2-1.3.2p1&src&util¶m).txt)(See
attached file: mpid_vc.c(mpich2-1.3.2p1&src&mpid&ch3&src).txt)(See attached
file: init.c(mpich2-1.3.2p1&src&mpi&init).txt)(See attached file:
tcp_init.c(mpich2-1.3.2p1&src&mpid&ch3&channels&nemesis&nemesis&netmod&tcp).txt)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0007.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0009.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0010.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0011.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0012.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/99736403/attachment-0013.obj>
