[mpich-discuss] installing and using MPI_PUBLISH_NAME	andMPI_LOOKUP_NAME with mpich2
    Bernard Secher - SFME/LGLS
    bernard.secher at cea.fr
    Thu Jun 16 07:40:32 CDT 2011
My test program work very well with opnempi, but I want to use mpich2
too, if it is possible...
How can I use mpd  with mpich2 ?
Leon Yuhanov a écrit :
> hey,ditch hydra. use mpd its easier for quick simple stuff. move onto lam-mpi or open-mpi after that.
> Bernard Secher - SFME/LGLS <bernard.secher at cea.fr> wrote:
> When I tried to use hydra_nameserver I get the followinf error message
> when I launch my application:
> [secher at is209011 essai]$ [mpiexec at is209011] HYDU_sock_read
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/utils/sock/sock.c:223):
> read errno (Input/output error)
> [mpiexec at is209011] control_cb
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:249):
> assert (!closed) failed
> [mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/tools/demux/demux_poll.c:77):
> callback returned error status
> [mpiexec at is209011] HYD_pmci_wait_for_completion
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:206):
> error waiting for event
> [mpiexec at is209011] main
> (/data/tmplgls/secher/mpich2-1.3.2p1-src/src/pm/hydra/ui/mpich/mpiexec.c:404):
> process manager error waiting for completion
> What is wrong
> My application is just a little test program. I have attached it to this
> message.
> Bernard
> Pavan Balaji a écrit :
>> [please keep mpich-discuss cc'ed]
>> On 06/16/2011 02:18 AM, Bernard Secher - SFME/LGLS wrote:
>>> How can I use the default publish mechanism? My Publish/lookup is
>>> hapenning between two different applications. Is there an option to give
>>> to mpiexec for that ?
>> Do you have a shared file-system? If yes, you don't need to modify
>> anything. It should just work. If no, then read below:
>>> If I use the pmi option, the mpiexec -nameserver -help give the
>>> following message:
>>> -nameserver: Nameserver to use for publish/lookup (format is host:port)
>>> I don't understand what I have to do with this option.
>>> First I launch the hydra_nameserver . Do I give some options to
>>> hydra_nameserver ? Do I give some options then, to the two mpiexec to
>>> launch my two applications?
>> There are no options required for hydra_nameserver. The two mpiexec's
>> will need the -nameserver {hostname} option, where {hostname} is the
>> name of the host where the nameserver is running.
>>  -- Pavan
       _\\|//_
      (' 0 0 ')
____ooO  (_) Ooo______________________________________________________
 Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto : bsecher at cea.fr
 CEA Saclay, Bât 454, Pièce 114        Phone  : 33 (0)1 69 08 73 78
 91191 Gif-sur-Yvette Cedex, France    Fax    : 33 (0)1 69 08 10 87
------------Oooo---------------------------------------------------
       oooO (   )
        \ ( (_/
         \_)
Ce message électronique et tous les fichiers attachés qu'il contient
sont confidentiels et destinés exclusivement à l'usage de la personne
à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
merci d'en avertir immédiatement son émetteur et de ne pas en conserver
de copie.
This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual to whom they are addressed.
If you have received this e-mail in error please inform the sender
immediately, without keeping any copy thereof.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110616/d7ebdca2/attachment.htm>
