[mpich-discuss] Problem with tcsh and ppn >= 5
    Frank Riley
    fhr at rincon.com
    Tue Jun 14 14:20:17 CDT 2011
Hello,
We are having a problem running more than 4 processes per node when using the tcsh shell. Has anyone seen this? Here is a simple test case:
mpiexec -n 1 -ppn 5 /bin/csh -c  /path/to/a.out
where a.out is a simple C test executable that does a MPI_Init and a MPI_Finalize. The error is as follows:
[cli_3]: write_line error; fd=18 buf=:cmd=init pmi_version=1 pmi_subversion=1
system message for write_line failure : Bad file descriptor
Note that the following command (bash shell) works fine:
mpiexec -n 1 -ppn 5 /bin/sh -c  /path/to/a.out
Our mpich2 is version 1.3.2p1 and is built with the following flags:
--enable-fast --enable-romio --enable-debuginfo --enable-smpcoll
--enable-mpe --enable-threads=runtime --enable-shared --with-mpe
