[mpich-discuss] Problem about MPI Program
Jayesh Krishna
jayesh at mcs.anl.gov
Sat Jun 11 21:27:26 CDT 2011
Which version of MPICH2 are you using (Which OS ?) ? Can you send us a test program that fails ?
Jayesh
----- Original Message -----
To: "jayesh" <jayesh at mcs.anl.gov>
Sent: Saturday, June 11, 2011 3:25:31 AM
Subject: Problem about MPI Program
hi, I'm an undergraduate from China. Recently I've met some problems about mpi running between machines.I use MPI_Isend and MPI_Irecv to communication while MPI_Waitall to test.It is successful
when i ran the program on a single machine or different machines with sending small message.But when i was sending message which is about 100k,it is failed.We received the message"MPI_Waitall (count=12,req_array=..,status_array=..) failed, read from socket failed ".I wonder if there are not enough message cache area.But how to set this area's size.Please help us.
